Using ESP logging with Adafruit ESP32-S2 Feather
bobbertolino
Post by bobbertolino »
Good morning,
I can't seem to get native ESP logging (e.g. log_i or ESP_LOGE) on the Adafruit ESP32-S2 Feather. This worked with other boards.
e.g.
esp_log_level_set("*", ESP_LOG_ERROR);
log_i("Hello!");
ESP_LOGE("Hello2");
Any advice?
Thank you,
Bob
mikeysklar
Re: Using ESP logging with Adafruit ESP32-S2 Feather
Post by mikeysklar »
The logging library is supported with the ESP32-S2 chips.
https://github.com/espressif/arduino-esp32
Which version of the ESP arduino core do you have installed? Is it 2.0.7 the latest?
It does look as though this is a flag that needs to be included at compile time so make sure you see that in your verbose compilation output.
target_compile_definitions(${COMPONENT_LIB} PUBLIC "-DLOG_LOCAL_LEVEL=ESP_LOG_VERBOSE")
bobbertolino
Hello. Thank you for the response. Yes, I'm using 2.0.7. I confess I'm building with the Arduino IDE. I did edit .\packages\esp32\hardware\esp32\2.0.7\platform.txt to include the LOG_LOCAL_LEVEL setting just to be safe; however, I the setting under Tools->"Core Debug Level" was also set to INFO.
I have no problem with Serial.print() statements. I just can't seem to get log_i() or ESP_LOGI working after setting esp_log_level_set("*", ESP_LOG_ERROR); as it does on another board I'm using.
mikeysklar
Since it works with another board and is supposed to be supported with the ESP32-S2 you might want to open an issue with the espressif arduino core.
https://github.com/espressif/arduino-esp32/issues
bobbertolino
Seems Serial.setDebugOutput(true) is required. I also encountered and identified another issue that has been reported and patched. See https://github.com/espressif/arduino-esp32/pull/7284
Although the output isn't flushed on each write, the logging does effectively work.
mikeysklar
Oh, thank you for the setDebug flag. At least we know it can work until the flushing issue comes up. It doesn’t look like the patch code was fully accepted yet if I’m reading that issue correctly.
