Adafruit DRV2605L Haptic Controller Delay Question
ZachGoode331
Post by ZachGoode331 »
Hi, I am using an Adafruit DRV2605L Haptic Controller for a coin vibration motor and a Jetson Nano. After initializing the I2C bus and DRV2065 module and trying to run play the sequence, it takes 10 seconds for the motor to start to vibrate. How do I decrease the amount of time it takes until my motor vibrates?
Below is my code:
class Motor:
 # Initalize I2C bus and DRV2065 module
        self.i2c = busio.I2C(board.SCL, board.SDA)
        self.drv = adafruit_drv2605.DRV2605(self.i2c)
        # Set effect number
        self.effect_num = effect_num
   def run(self,run_time=5):
        # Run vibrations
        self.drv.sequence[0] = adafruit_drv2605.Effect(self.effect_num)
        # Run for five seconds then stop
        self.drv.play()
        time.sleep(run_time)
        self.drv.stop()
Reason: Add code tags
dastels
Re: Adafruit DRV2605L Haptic Controller Delay Question
Post by dastels »
It should be instantaneous unless the library is grossly over complex.
Could you post all the code?
Why is this in a class? There's nothing in what you posted that requires (or benefits from) being in a class.
ZachGoode331
Hi Dave, thank you for your help. I put it in a class because it's part of a larger project where I'll be taking input from microphones, running an ML model, getting a result, and run different devices based on this result including these pancake motors, LED lights, etc. I'll have a single file that imports the different classes for these devices to run them from one place.
This is the library for the DRV2605L Haptic Controller: https://github.com/adafruit/Adafruit_DRV2605_Library
This is the example code I used to help me write the code below: https://learn.adafruit.com/adafruit-drv ... cuitpython
This is the code for the pancake motors and DRV2605L haptic controller. Please let me know if you need more info. Thank you:
import board
import busio
import adafruit_drv2605
import time
class Steering_Wheel_MotorController:
def __init__(self, effect_num=118):
# Set effect number
# Run vibrations
self.drv.play()
self.drv.stop()
This is the code pertaining to the pancake motors and DRV2605L haptic controller in my single file that runs all my devices:
from steering_wheel_motor_control import Steering_Wheel_MotorController
# Running Steering Wheel Motors
steering_wheel_mc = Steering_Wheel_MotorController(effect_num=118)
steering_wheel_mc.run()
ZachGoode331
Hi nevermind figured it out. The controller has a real-time playback mode that allows the host processor to bypass the library.
