I just started working with the Adafruit Feather RP2040 SCORPIO. I have been running through their documentation. I loaded the correct version of circuitPython (8x). Mu runs with everything fine on the drive (CIRCUITPY) - until I ask for it to load the NeoPxl8 library (from adafruit_neopxl8) - it gives me an ImportError : no module named 'adafruit_neopxl8'. I checked the installed modules and that doesn't exist - it also doesn't show as a separate library, it is not in the bundles (any of them - the circuitpython-bundle-8x in particular). in the tutorial on adafruit it looks like it should simply be included in the original circuitpython but when I looked into it it doesn't seem to be included there either. Any suggestions?
I have actually been using arduino and it's native language for years but I am trying to work with python for the first time. It's been a little confusing and I apologize ahead of time for my awkwardness on this question.
neopxl_8 library not found
- mikeysklar
Re: neopxl_8 library not found
Did you download the project bundle or adafruit_neopxl8 from the CircuitPython library bundle?
It should look more or less like this on your CIRCUITPY drive.
https://learn.adafruit.com/introducing- ... it_neopxl8
- niemczyk
I do now. Thank you very much.
- niemczyk
although I still don't see it in the circuitPython library bundle. Thank you for the project link.
- mikeysklar
Were you able to get the neopxl_8 working with the project bundle?
Here is a higher level link to the full libraries. You would want to download Bundle for version 8.x.
