Code won't compile on Feather 32u4
jspring111
Post by jspring111 »
I wrote code which compiles and runs fine on a 328P Nano. But when I tried to compile it for a Feather 32u4 RFM69HCW it won't compile. And yes I did change the board in the Arduino IDE Feather 32u4. Any idea why the problems? The errors are attached: (sorry if I posted the errors in the wrong way)
There are so many and I don't know which one made it fail.
Thanks for looking at this
Feather 32u4 RFM69 Errors.txt
(149.35 KiB) Downloaded 11 times
dastels
Re: Code won't compile on Feather 32u4
Post by dastels »
There is some MCU specific code. Errors like:
C:\Users\jspri\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp:444:5: error: 'OCR2A' was not declared in this scope
     OCR2A = nticks;
OCR2A is a hardware level detail. The 328 and 32u4 are different MCUs.
See https://forum.arduino.cc/t/move-from-32 ... ues/348294 for more discussion.
jspring111
My project has a Feather 32u4 RFM69HCW running at 433mhz. I wrote my sketch using the Radiohead library as Directed in the Adafruit instructions. Are you telling me the Feather 32u4 RFM69HCW is not compatible with the Radiohead Library because it's not a 328P processor? Adafruit does not make a Feather 328P RFM69HCW as far as I know.
dastels
Post by dastels »
There is 32u4 support. See RadioHead.h in the library:
- Adafruit Feather. These are excellent boards that are available with a variety of radios. We tested with the
Feather 32u4 with RFM69HCW radio, with Arduino IDE 1.6.8 and the Adafruit AVR Boards board manager version 1.6.10.
https://www.adafruit.com/products/3076
Is everything up to date (board support and libraries)? You installed the Adafruit fork of the RadioHead library: https://github.com/adafruit/RadioHead/a ... master.zip? It looks like it doesn't know it's compiling for a 32u4.
Return to “Arduino”
