Hi, can you advise me how to use the APDS-9960 sensor as follows:
collect proximity data and take an action at a specific value
ambient light and color measurement
listen for gestures
all at the same time
I use this lib for arduino:
https://github.com/adafruit/Adafruit_APDS9960
Thx for repply.
more functions on APDS-9960 at the same time
- mikeysklar
Re: more functions on APDS-9960 at the same time
This sensor has a complete guide and three sets of example code for color, gesture and proximity. That should be plenty to get you going.
- duskohu
Thx, for reply,
Yes, but if I use the examples all at once, it doesn't work.
- mikeysklar
Have you run them each independently successfully?
Go ahead and post your combined code attempt.
- duskohu
now I chnged arduino uno to arduino nano every.
first problem: example
https://github.com/adafruit/Adafruit_AP ... sensor.ino
failed to initialize device! Please check your wiring.
on arduino uno work.
- mikeysklar
Go ahead and post a photo of your wiring. Probably a pin change.
- duskohu
I have connections:
Arduino nano every > APDS-9960
GND > GND
3.3V > VCC
SDA(D18) > SDA
SCL(D19) > SCL
D3 > INT
GND > GND
3.3V > VCC
SDA(D18) > SDA
SCL(D19) > SCL
D3 > INT
- mikeysklar
The pins you are using sound right. I just need to see the soldering quality, cable lengths and whatever wildcard factors are at play with a photo and code you are uploading.
- duskohu
code: https://BANNED.com/XZBGV6Uq
When I connct another sensor for example MPR121 its work
images in Attachment
- Attachments
- 1.jpg (660.87 KiB) Viewed 57 times
- 2.jpg (814.81 KiB) Viewed 57 times
- mikeysklar
This is not an Adafruit APDS-9960 sensor. You will need to seek support from the vendor.
