TSSOP-28
Big_Will
TSSOP-28
Post by Big_Will »
I need pins for the P1208B to fit regular DIP socket
bidrohini1
Re: TSSOP-28
Post by bidrohini1 »
Hello, exactly which product did you mean? Could you please share the link?
adafruit_support_carter
Re: TSSOP-28
This is the product:
https://www.adafruit.com/product/1208
Need a better definition of "regular DIP" though. Like 0.3" wide, 0.6" wide, etc?
Big_Will
Re: TSSOP-28
Post by Big_Will »
Link to Adafruit SOIC-28 to DIP adaptor (1208)
Link to the type socket (Mill-Max PN 110-13-628-41-001000) that I need pins for the 1208 to mate to.
https://www.mouser.com/ProductDetail/Mi ... IqHQ%3D%3D
This type 0.6, 28 pin socket is available from several manufacturers.
Re: TSSOP-28
Looks like the PID 1208 breakout will work. Its row spacing matches:
Big_Will
Re: TSSOP-28
Post by Big_Will »
Yes, I have the 1208 (3 pieces). However, I need the pins that will allow me to plug the 1208 into a standard IC DIP socket like the one I sent in my last post. Can you recommend a part number and source for the pins? Thank you.
Re: TSSOP-28
Oh, you mean the actual header pins? Like what goes here?
They're nothing special. Just the very common 0.1" (2.54mm) spaced header pins. These will work:
https://www.adafruit.com/product/392
Big_Will
Re: TSSOP-28
Post by Big_Will »
Exactly, yes, yes. So many use the bigger square pins, but I need the pins that are smaller and fit into a IC socket. Thanks
Re: TSSOP-28
Probably worth also mentioning these as an option:
https://www.adafruit.com/product/3647
In general, those are just "fancier" versions of the same headers.
Big_Will
Re: TSSOP-28
Post by Big_Will »
Okay, these appear to fit an IC socket. Certainly worth looking into. Thanks for all your help.
