I have a clock project using a Feather M0 Express which has a LiPo battery attached.
I have written a section in my code which senses when the battery is at or below 3.5v and then sounds a beep. In this case I ran a test and when the battery arrived at a certain point the voltage dropped to the point where the system stopped. I then reattached the USB power but the beep continued to sound until the battery power was over 3.5v.
Is there any way that I can know that the Feather is now being powered by USB power and the battery is being charged?
How to know when USB power is connected?
- adafruit_support_bill
Re: How to know when USB power is connected?
You can monitor the USB pin with an analog pin to measure the bus voltage. You will need to use a voltage divider as is done on the battery monitoring circuit to scale the bus voltage to a safe level for the M0 analog pin.
https://learn.adafruit.com/adafruit-fea ... ry-3122383
- Gambalunga
Thanks for the reply.
Just to make sure I understand I would more or less duplicate the voltage divider used for the battery. The resistors could be mounted on the prototyping section. It would be as the image below:
The code to control whether or not the USB power is connected would not even have to double the measured voltage because we are only interested to know if the USB power is active so any voltage greater than, say 2.3 V (to allow for some possible variation) should tell me that USB power is attached (or if doubled > 4.6 V).
Have I understood correctly?
Peter
Peter
Yes. That should do it.
- alpierce
You might think about using 100k resistors if power consumption is at all a concern, and the divider voltage is also a logic high level if you want to use digital input and avoid voltage comparisons.
- Gambalunga
I am not worried about power consumption. I really only want to know if the USB power is connected or, more correctly, if the LiPo battery is being charged. However it was my intention to use 100k resistors. The 1k in the design was one of those midnight lapses in concentration. :-(
The idea of using the divider output as a digital input is a good one, I will see if I can get that working. Thanks.
Peter
