MAGTAG and Stemma soil sensor
conyerbd
Post by conyerbd »
Hey all,
This is the first project I've worked on and I'm a bit stuck getting my Magtag to recognize the stemma soil sensor.
Here's a pic of it plugged in. Ignore the running code on the display.
Using the sample code below I get an error that there's no device at the address 0x36. I've tried both the board.I2C and board.STEMMA_I2C without success.
import time
import board
from adafruit_seesaw.seesaw import Seesaw
i2c_bus = board.I2C()  # uses board.SCL and board.SDA
# i2c_bus = board.STEMMA_I2C()  # For using the built-in STEMMA QT connector on a microcontroller
ss = Seesaw(i2c_bus, addr=0x36)
while True:
    # read moisture level through capacitive touch pad
    touch = ss.moisture_read()
    # read temperature from the temperature sensor
    temp = ss.get_temp()
    print("temp: " + str(temp) + "  moisture: " + str(touch))
    time.sleep(1)
I thought maybe it could be at a different address and running an i2c scan all I get is 0x19 (which shows up even when nothing in plugged in) wondering if this is the battery or some onboard device.
Either way, I'm a bit stuck. The pinouts all seem to match up
I really appreciate any advice. I'm feel like I've probably missed something basic.
Thank and have a great day!
conyerbd
Re: MAGTAG and Stemma soil sensor
Post by conyerbd »
Small update that I tested another stemma I2C device which was immediately picked up by the MagTag. So the issue is either with the soil sensor, the cable or a small chance some strange incompatibility with the soil sensor and MagTag.
adafruit_support_carter
As another check, try running an I2C scan on the MagTag with the Soil Sensor attached:
https://learn.adafruit.com/scanning-i2c ... s/overview
See if at least the address will show up in the scan?
conyerbd
Post by conyerbd »
Thanks for the response,
I've tried an I2C scan with everything plugged in and it only finds 0x19 which is the built in accelerometer.
I wish I had another soil sensor to see if there's something wrong with this one.
Let's just replace the Soil Sensor.
Send an email to [email protected] with a link to this thread and your order number and they can send you a replacement STEMMA Soil Sensor.
conyerbd
Post by conyerbd »
Wow! I'm lucky enough to have a Microcenter down the street where I could quickly pick up a spare. Lo and behold it works!
Guess I just got really unlucky with my first order. I'll still follow up with the replacement as I'd like to have several eventually.
Thanks again for all the help!
Cool. Glad the other one worked. Yep - please go ahead and email for a replacement.
If you still happen to have the plastic bag the non-working Soil Sensor came in, please post a photo of it showing the white sticker with barcode and logo.
