ESP-32 S3 TFT Reverse AWS IoT not working
MakerAL
Post by MakerAL »
I am trying the AWS IoT example from: https://github.com/adafruit/Adafruit_Ci ... on_AWS_IOT
on ESP-32 S3 TFT reversed which has CircuitPython installed
My code as below:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
import time
import json
import board
import busio
import displayio
import digitalio
import adafruit_requests as requests
from digitalio import DigitalInOut
import neopixel
from adafruit_esp32spi import adafruit_esp32spi
from adafruit_esp32spi import adafruit_esp32spi_wifimanager
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_aws_iot import MQTT_CLIENT
### WiFi ###
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# Get device certificate
try:
    with open("aws_cert.pem.crt", "rb") as f:
        DEVICE_CERT = f.read()
except ImportError:
    print("Certificate (aws_cert.pem.crt) not found on CIRCUITPY filesystem.")
    raise
# Get device private key
try:
    with open("private.pem.key", "rb") as f:
        DEVICE_KEY = f.read()
except ImportError:
    print("Certificate (private.pem.key) not found on CIRCUITPY filesystem.")
    raise
# If you are using a board with pre-defined ESP32 Pins:
#esp32_cs = DigitalInOut(board.ESP_CS)
#esp32_ready = DigitalInOut(board.ESP_BUSY)
#esp32_reset = DigitalInOut(board.ESP_RESET)
# If you have an externally connected ESP32:
esp32_cs = DigitalInOut(board.D9)
esp32_ready = DigitalInOut(board.D10)
esp32_reset = DigitalInOut(board.D5)
#spi = board.SPI()
spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
# Verify nina-fw version >= 1.4.0
assert (
    int(bytes(esp.firmware_version).decode("utf-8")[2]) >= 4
), "Please update nina-fw to >=1.4.0."
# Use below for Most Boards
status_light = neopixel.NeoPixel(
    board.NEOPIXEL, 1, brightness=0.5
wifi = adafruit_esp32spi_wifimanager.ESPSPI_WiFiManager(esp, secrets, status_light)
### Code ###
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connect(client, userdata, flags, rc):
    # This function will be called when the client is connected
    # successfully to the broker.
    print("Connected to MQTT Broker!")
    print("Flags: {0}\n RC: {1}".format(flags, rc))
    # Subscribe client to all shadow updates
    print("Subscribing to shadow updates...")
    aws_iot.shadow_subscribe()
def disconnect(client, userdata, rc):
    # This method is called when the client disconnects
    # from the broker.
    print("Disconnected from MQTT Broker!")
def subscribe(client, userdata, topic, granted_qos):
    # This method is called when the client subscribes to a new topic.
    print("Subscribed to {0} with QOS level {1}".format(topic, granted_qos))
    # Update device shadow with example JSON payload
    payload = {"state": {"reported": {"moisture": 50, "temp": 30}}}
    aws_iot.shadow_update(json.dumps(payload))
    # We can also retrieve the shadow from AWS IoT,
    # aws_iot.shadow_get()
    # or delete the shadow
    # aws_iot.shadow_delete()
def unsubscribe(client, userdata, topic, pid):
    # This method is called when the client unsubscribes from a topic.
    print("Unsubscribed from {0} with PID {1}".format(topic, pid))
def publish(client, userdata, topic, pid):
    # This method is called when the client publishes data to a topic.
    print("Published to {0} with PID {1}".format(topic, pid))
def message(client, topic, msg):
    # This method is called when the client receives data from a topic.
    print("Message from {}: {}".format(topic, msg))
# Set AWS Device Certificate
esp.set_certificate(DEVICE_CERT)
# Set AWS RSA Private Key
esp.set_private_key(DEVICE_KEY)
# Connect to WiFi
print("Connecting to WiFi...")
wifi.connect()
print("Connected!")
# Initialize MQTT interface with the esp interface
MQTT.set_socket(socket, esp)
# Set up a new MiniMQTT Client
client = MQTT.MQTT(broker=secrets["broker"], client_id=secrets["client_id"])
# Initialize AWS IoT MQTT API Client
aws_iot = MQTT_CLIENT(client)
# Connect callback handlers to AWS IoT MQTT Client
aws_iot.on_connect = connect
aws_iot.on_disconnect = disconnect
aws_iot.on_subscribe = subscribe
aws_iot.on_unsubscribe = unsubscribe
aws_iot.on_publish = publish
aws_iot.on_message = message
print("Attempting to connect to %s" % client.broker)
aws_iot.connect()
# Pump the message loop forever, all events
# are handled in their callback handlers
# while True:
#   aws_iot.loop()
# Start a blocking message loop...
# NOTE: NO code below this loop will execute
# NOTE: Network reconnection is handled within this loop
while True:
    try:
        aws_iot.loop()
    except (ValueError, RuntimeError) as e:
        print("Failed to get data, retrying\n", e)
        wifi.reset()
        aws_iot.reconnect()
        continue
    time.sleep(1)
I've been getting this error:
TimeoutError: ESP32 timed out on SPI select
It seems like SPI can't be used for this board, anyone has insights?
mikeysklar
Re: ESP-32 S3 TFT Reverse AWS IoT not working
Post by mikeysklar »
Your board is a real ESP32-S3 not a co-processor or AirLift setup which this library and example code is using.
You can request support be added for ESP32 direct boards. It seems totally feasible to add more conditional code to support native ESP32 boards.
https://github.com/adafruit/Adafruit_Ci ... is%3Aissue
MakerAL
Post by MakerAL »
mikeysklar wrote: Thu Mar 23, 2023 2:56 pm Your board is a real ESP32-S3 not a co-processor or AirLift setup which this library and example code is using.
Thanks for confirming. My research somewhere came to the same conclusion. I will raise an issue with the maintainer.
neradoc
Post by neradoc »
It uses a MQTT instance, you can try changing the setup of the MQTT object based on the native wifi example:
https://github.com/adafruit/Adafruit_Ci ... working.py
It might look something like that, though I can't test the AWS code:
import time
import json
import board
import busio
import ssl
import socketpool
import wifi
import neopixel
### WiFi ###
try:
except ImportError:
    raise
try:
except ImportError:
    raise
try:
except ImportError:
    raise
    board.NEOPIXEL, 1, brightness=0.2
)  # Uncomment for Most Boards
### Code ###
topic = "circuitpython/aws"
    # Subscribe to topic circuitpython/aws
    print("Subscribing to topic {}".format(topic))
    aws_iot.subscribe(topic)
    # from the broker.
    # Create a json-formatted message
    message = {"message": "Hello from AWS IoT CircuitPython"}
    # Publish message to topic
    aws_iot.publish(topic, json.dumps(message))
# Connect to WiFi
wifi.radio.connect(secrets["ssid"], secrets["password"])
print("Connected!")
# Create a socket pool
pool = socketpool.SocketPool(wifi.radio)
# Set up a MiniMQTT Client
client = MQTT.MQTT(
    client_id=secrets["client_id"],
    socket_pool=pool,
    ssl_context=ssl.create_default_context(),
aws_iot.connect()
# while True:
#   aws_iot.loop()
while True:
    try:
        aws_iot.loop()
        wifi.reset()
        aws_iot.reconnect()
        continue
    time.sleep(1)
