I am using the Adafruit stepper motor and the Adafruit DC & Stepper Motor HAT for Raspberry Pi
https://www.adafruit.com/product/2348
https://www.adafruit.com/product/324
I am using a power supply that will have 12V and 10A. Can I plug directly into the system? Is there something I can use to step down the amperage before going into the system?
Thank you for the help!
Powering Stepper Motor and Motor Controller
- sj_remington
Re: Powering Stepper Motor and Motor Controller
10A is not a problem. Circuits draw the current they require.
For best results, the power supply should be capable of supplying significantly more than the required current.
- adafruit_support_bill
You can connect your power supply directly to the external power terminals on the Motor HAT. As mentioned above, the motor will draw only what it needs. The #324 motor typically draws about 0.7A max.
