Faulty MLX90640 Board
arnegue
Post by arnegue »
Hi Support Team,
just purchased a MLX90640 breakout board (ADA4407) and tested it. Used the original code from here https://github.com/adafruit/Adafruit_MLX90640 but was unable to get any data/connection.
After that I tested if i can see the camera at least as I2C device (tested with http://arduinolearning.com/code/i2c-scanner.php). Unfortunately without success.
Also tried all ports (left and right QWIIC connector as well as the onboard pin holes), and everything in combination with a XIAO NRF52840 and an original Arduino UNO. The only thing working is the onboard LED.
The soldering of the MLX itself don´t seem to be perfect, but this shoud not influence the visibility as I2C device, right? Also the 6-pin chip above the SDA pin hole is rotated (see attached image).
Any suggestions?
Best
Arne
P.S.: As I haven´t found the information somewhere else: can I adjust the focus of the camera by rotating the lens? Or is it fixed focus? This would explain why I can´t move the lens.
P.P.S: ADA4407 bought at berrybase.de, Germany
mikeysklar
Re: Faulty MLX90640 Board
Post by mikeysklar »
This board does look potentially faulty based on the partially rotated component and solder blobs not being completely melted in the center.
What controller had you been connecting it to when running the stock Arduino example and i2c code?
We can start the replacement process with you. Can you e-mail [email protected] and provide them with this forum thread. Since you purchased from another vendor you won’t have an Adafruit order#, but provide them with the berrybase order# and supplier info.
arnegue
Post by arnegue »
Thanks for the fast response. I checked both example codes with the XIAO nrf52840 and also with an UNO.
To replace the camera the berrybase website (https://support.berrybase.de/index.php? ... eintrag=27, german!) tells me to send them the link to this thread where you confirm the replacement. Do I still have to e-mail to your support and then you will contact berrybase? Just want to do it right without any confusion and too much "paperwork".
Best
Arne
adafruit2
Post by adafruit2 »
S3 boards have finicky I2C - did you try another board? the soldering and component placement on the board looks OK
arnegue
Post by arnegue »
arnegue wrote: Thu Mar 23, 2023 7:24 am ...
arnegue wrote: Thu Mar 23, 2023 4:58 pm ...
Please see above the boards I tested it with. I assume that only the XIAO board is a "S3 board", not the Arduino UNO, right?
adafruit2
Post by adafruit2 »
ok one more question because its worth checking - look at the QT cable or try soldering to the breakout pads, in case the cable or connector its plugging into is damaged? (look in the connector, is a pin bent)
we have no issue replacing but these cameras are tested and don't tend to fail
arnegue
Post by arnegue »
Checked the QT cable once again (as already the first time) on both connectors. Both connectors are fine also, no pins bent.
Additionally I tried with success that my Arduino UNO and the XIAO were OK by letting them communicate via I2C witch each other (sending data to let a LED light up). Then tried again if the I2CScanner can find the camera with both UNO/XIAO. That failed.
adafruit2
Post by adafruit2 »
ok thanks! worth a shot :)
Opzet
Post by Opzet »
This sucks... Cannot use ESP32 One Camera (esp_camera.h) and Adafruit_MLX90640.h i2c contention. HAL onion isn't very good.
Adafruit_MLX90640 detects and configures camera over I2C interface, it leave ISR and stops MXL90640 from being detected after initial read.
* allocates framebuffer and DMA buffers,
* initializes parallel I2S input, and sets up DMA descriptors.
* Currently this function can only be called once and there is
* no way to de-initialize this module.
E (96743) gpio: gpio_install_isr_service(449): GPIO isr service already installed
E (96856) cam_hal: cam_config(397): cam intr alloc failed
Opzet
Post by Opzet »
This is a really nice working MXL90640 sketch with ASCII art
#include <Adafruit_MLX90640.h>
Adafruit_MLX90640 mlx;
float frame[32*24]; // buffer for full frame of temperatures
// uncomment *one* of the below
#define PRINT_ASCIIART
MLX90640 Temp Frame Render
Found MLX90640
Serial number: 161FCB2F189
Current mode: Interleave
Current resolution: 18 bit
Current frame rate: 16 Hz
****-***++xx++**-*****++********
***-*-***+xxx+**--***++++***--**
**-****+*+xxxx******+xx+++******
******++*+xx+x+*-****+xx+***--**
****++x+*+xxxx+*****++xxx++*****
-**+++x+**x%xx++--***+xx++**-**+
****+++x+*xxxxx+*****+xxx+*+*++*
****++xx+*+xxxx+*****+xxx+++++++
*+*+++xx+++xxxxx*****+xx%x++++++
****++xxx++xxxx%*****+xx+x++**++
***+*xxxx++xxxxx++**+xxxxx*+*+**
*****+xxx++xxx%x++***+xxxx*+***+
***+++xxxx+x%%%%x+-++x%%xx*+**+*
*+****BANNED%x%%x+**+xxxxx+*****
+*+++*BANNED%xxxx+*+xx%xx*++*+*
+*+***+BANNED**+xxxxx+*-***
x+**+++xxxx%%xx%x%++xx%%xx+*+*++
++++**++xxx%xx%xxx+++xx%xx++***+
//#define PRINT_TEMPERATURES
27 28 26 26 27 26 26 26 26 26 25 27 26 25 25 25 25 26 25 26 26 26 26 24 27 25 25 25 27 26 25 26
26 25 26 25 25 25 25 26 25 24 26 25 26 25 25 25 25 25 26 26 25 25 27 26 26 25 27 26 25 25 26 27
24 26 25 26 26 26 26 27 25 26 26 25 26 26 25 25 26 26 26 27 26 25 25 25 26 26 26 27 26 27 23 26
25 25 27 24 26 25 26 26 26 26 26 26 25 25 25 26 25 25 25 25 25 25 26 26 25 25 27 27 24 26 26 27
27 25 27 25 27 25 25 25 25 26 25 25 26 26 25 26 25 26 26 26 25 26 25 25 25 27 26 25 27 26 25 27
25 26 27 28 27 27 27 27 25 25 25 25 25 25 25 25 26 24 26 26 26 25 25 26 26 25 26 26 25 27 26 25
27 28 30 29 29 29 29 29 27 26 25 26 25 26 26 26 25 26 26 26 26 26 26 26 26 26 26 26 27 28 25 27
27 28 30 29 28 29 31 29 26 26 25 26 25 24 25 26 24 25 26 25 25 25 26 25 26 26 26 26 25 27 26 26
29 29 29 30 30 29 29 30 29 28 25 25 26 25 25 25 26 26 25 25 26 26 26 26 26 26 26 26 26 25 26 26
30 28 28 30 29 28 29 30 29 27 26 25 25 24 26 25 25 26 26 26 25 25 26 27 26 26 26 26 26 26 27 26
30 30 29 30 30 30 29 29 28 29 27 26 26 26 26 25 25 26 26 26 25 26 26 26 25 26 25 26 26 27 26 26
28 28 29 30 28 29 29 29 29 29 27 26 24 25 26 25 26 25 26 25 25 26 26 26 27 26 26 27 25 26 26 25
30 29 29 29 29 30 30 30 30 30 28 27 26 26 26 26 26 26 25 26 25 26 26 26 26 26 26 26 27 28 26 27
28 30 28 29 29 29 29 29 29 30 29 28 25 26 27 26 25 26 26 26 25 25 26 27 26 26 27 28 26 28 27 28
31 30 29 29 30 29 30 31 30 30 29 29 26 27 26 26 26 26 26 27 25 26 26 25 27 27 27 28 27 29 27 27
29 30 30 29 30 29 29 30 30 30 29 27 26 26 27 26 26 26 26 26 25 25 26 27 26 27 27 27 27 26 27 27
31 30 29 31 31 30 30 30 31 30 30 29 26 27 26 26 26 26 26 25 25 26 26 27 27 27 26 26 27 26 27 26
30 29 29 30 29 29 30 30 29 29 31 30 26 26 26 26 26 26 26 26 25 25 26 26 25 27 26 27 26 26 26 28
31 31 30 31 31 31 30 30 31 30 30 30 28 27 26 26 26 25 26 27 26 25 25 26 26 27 26 26 25 27 26 26
29 29 31 30 31 31 30 30 30 29 31 30 27 27 26 27 26 26 25 26 26 25 26 26 25 27 25 27 25 26 25 27
30 29 31 31 30 30 31 31 30 30 30 29 27 27 26 26 26 26 26 26 26 27 26 25 27 27 26 27 27 26 27 27
28 29 30 32 30 30 31 31 29 30 30 30 27 28 25 25 26 25 25 25 25 26 26 26 26 26 27 27 26 25 27 27
27 30 31 32 31 31 30 31 31 32 30 30 29 28 26 25 26 26 26 26 27 26 26 26 27 26 27 27 26 26 27 27
27 29 31 31 30 30 30 30 30 29 30 30 29 28 26 26 26 25 26 25 25 26 25 25 25 27 25 27 26 26 26 27
  Serial.begin(921600);
  Serial.println("MLX90640 Temp Frame Render");
  delay(100);
  pinMode(18, INPUT_PULLUP); // enable pull-up resistor for SDA pin
  pinMode(23, INPUT_PULLUP); // enable pull-up resistor for SCL pin
  Wire.begin(18, 23); // set SDA to pin 18 and SCL to pin 23
  Wire.setClock(400000); // set I2C bus speed to 400kHz
  if (! mlx.begin(MLX90640_I2CADDR_DEFAULT, &Wire)) {
    Serial.println("MLX90640 not found!");
    while (1) delay(10);
  Serial.println("Found MLX90640");
  Serial.print("Serial number: ");
  Serial.print(mlx.serialNumber[0], HEX);
  Serial.print(mlx.serialNumber[1], HEX);
  Serial.println(mlx.serialNumber[2], HEX);
  Wire.setClock(1000000); // set I2C bus speed to 800kHz
  //mlx.setMode(MLX90640_INTERLEAVED);
  mlx.setMode(MLX90640_CHESS);
  Serial.print("Current mode: ");
  if (mlx.getMode() == MLX90640_CHESS) {
    Serial.println("Chess");
  } else {
    Serial.println("Interleave");
  mlx.setResolution(MLX90640_ADC_18BIT);
  Serial.print("Current resolution: ");
  mlx90640_resolution_t res = mlx.getResolution();
  switch (res) {
    case MLX90640_ADC_16BIT: Serial.println("16 bit"); break;
    case MLX90640_ADC_17BIT: Serial.println("17 bit"); break;
    case MLX90640_ADC_18BIT: Serial.println("18 bit"); break;
    case MLX90640_ADC_19BIT: Serial.println("19 bit"); break;
  mlx.setRefreshRate(MLX90640_16_HZ);
  Serial.print("Current frame rate: ");
  mlx90640_refreshrate_t rate = mlx.getRefreshRate();
  switch (rate) {
    case MLX90640_0_5_HZ: Serial.println("0.5 Hz"); break;
    case MLX90640_1_HZ: Serial.println("1 Hz"); break;
    case MLX90640_2_HZ: Serial.println("2 Hz"); break;
    case MLX90640_4_HZ: Serial.println("4 Hz"); break;
    case MLX90640_8_HZ: Serial.println("8 Hz"); break;
    case MLX90640_16_HZ: Serial.println("16 Hz"); break;
    case MLX90640_32_HZ: Serial.println("32 Hz"); break;
    case MLX90640_64_HZ: Serial.println("64 Hz"); break;
  Serial.println("");
  if (mlx.getFrame(frame) != 0) {
    Serial.println("Failed");
    delay(500);
    return;
  Serial.println();
  Serial.println();
  for (uint8_t h=0; h<24; h++) {
    for (uint8_t w=0; w<32; w++) {
      float t = frame[h*32 + w];
#ifdef PRINT_TEMPERATURES
      Serial.print(t, 0);
      Serial.print(" ");
#endif
#ifdef PRINT_ASCIIART
      char c = '&';
      if (t < 28) c = ' ';
      else if (t < 29) c = '.';
      else if (t < 30) c = '-';
      else if (t < 31) c = '*';
      else if (t < 32) c = '+';
      else if (t < 33) c = 'x';
      else if (t < 34) c = '%';
      else if (t < 35) c = '#';
      else if (t < 36) c = 'X';
      Serial.print(c);
#endif
    Serial.println();
arnegue
Post by arnegue »
Thanks opzet for the sample code. I will try this out if everything is working.
@adafruit2: Is there anything else I can try or check? If not I guess we can define the board as faulty and replace it. If so:
Option 1: Do I send purchase details to [url]mailto:[email protected][/url] and you contact berrybase?
Option 2: I write berrybase directly and they will do the rest. (BTW: their branch is 500 m away from my office, so no shipping costs).
Best
Arne
