Compatibility of RPi camera flex cables
Quinten_
Post by Quinten_ »
Just wanted to make sure before I order: does the Flex Cable (https://www.adafruit.com/product/1731) work with the RPi camera v2 board (https://www.adafruit.com/product/3099)? The cable's product page says
This cable will let you swap out the stock 150mm long flex cable from a Raspberry Pi Camera (either 'classic' or 'NoIR' type) or Raspberry Pi Display for a different size. Works great, just carefully open the connector on the Pi and slip this one in.
However, I'm not sure if that hasn't been updated or if this cable does not work with newer models. The connector seems the same...
adafruit_support_carter
Re: Compatibility of RPi camera flex cables
Yep, it'll work. The V2 camera uses the same cable.
Return to “Adafruit Raspberry Pi® accessories”
