adafruit_requests setting timeout
mikek2
Post by mikek2 »
I am working on a simple display with an LED screen to fetch from an http server within a raspberry pi on my local network and display the value it returns on the screen. It connects just fine several times and displays the values properly, but after a few minutes it hangs on a connection and the display halts while this occurs. The only solution I have seen so far is to unplug it and plug it back in, but within a few minutes it starts hanging on the connection again.
I saw reference of a settimeout() function on https://docs.circuitpython.org/projects ... t/api.html. I have not been able to figure out how to use it though.
Here is the relevant code
def getRaspberryData():
    global display_text
    try:
        print("Fetching text from", raspberry_url)
        r = requests.get(raspberry_url)
        display_text = r.text
        r.close()
        print('received: ' + display_text)
        return display_text
    except Exception as e:
        print('error getting display text', e)
        return display_text
def initialSetup():
    global raspberry_url
    # Get wifi details and more from a secrets.py file
    try:
        from secrets import secrets
    except ImportError:
        print("WiFi secrets are kept in secrets.py, please add them there!")
        raise
    raspberry_url = secrets["raspberry"]
    # If you are using a board with pre-defined ESP32 Pins:
    esp32_cs = DigitalInOut(board.ESP_CS)
    esp32_ready = DigitalInOut(board.ESP_BUSY)
    esp32_reset = DigitalInOut(board.ESP_RESET)
    spi = busio.SPI(board.SCK, board.MOSI, board.MISO)
    esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
    requests.set_socket(socket, esp)
    print("Connecting to AP...")
    while not esp.is_connected:
        try:
            esp.connect_AP(secrets["ssid"], secrets["password"])
        except OSError as e:
            print("could not connect to AP, retrying: ", e)
            continue
    getRaspberryData()
The final output before it hangs:
received: Test message
Fetching text from http://[my-server-ip]:8000/output.txt
I don't particularly care if it fails every now and then, but since it is a single-threaded application it halts everything while it hangs. Ideally I would like some way to time out the get request.
(It seems to only occur when reaching out to the local raspberry pi, but I can still reach it from other devices on the network so I'm not sure what's going on with it)
Return to “Internet of Things: Adafruit IO and Wippersnapper”
