I'm trying to get the Adafruit nRF52840 USB key (https://www.adafruit.com/product/5199) working in Wireshark in Windows 11, using the instructions at: https://learn.adafruit.com/ble-sniffer-with-nrf52840
However, the nRF Sniffer never appears in the Capture menu of Wireshark, even if I run Wireshark as administrator.
I confirmed that running the command "nrf_sniffer_ble.bat --extcap-interfaces" in the Wireshark extcap directory runs, but does not display the interface:
extcap {version=4.1.1}{display=nRF Sniffer for Bluetooth LE}{help=https://www.nordicsemi.com/Software-and ... uetooth-LE}
control {number=0}{type=selector}{display=Device}{tooltip=Device list}
control {number=1}{type=selector}{display=Key}{tooltip=}
control {number=2}{type=string}{display=Value}{tooltip=6 digit passkey or 16 or 32 bytes encryption key in hexadecimal starting with '0x', big endian format.If the entered key is shorter than 16 or 32 bytes, it will be zero-padded in front'}{validation=\b^(([0-9]{6})|(0x[0-9a-fA-F]{1,64})|([0-9A-Fa-f]{2}[:-]){5}([0-9A-Fa-f]{2}) (public|random))$\b}
control {number=3}{type=string}{display=Adv Hop}{default=37,38,39}{tooltip=Advertising channel hop sequence. Change the order in which the sniffer switches advertising channels. Valid channels are 37, 38 and 39 separated by comma.}{validation=^\s*((37|38|39)\s*,\s*){0,2}(37|38|39){1}\s*$}{required=true}
control {number=7}{type=button}{display=Clear}{tooltop=Clear or remove device from Device list}
control {number=4}{type=button}{role=help}{display=Help}{tooltip=Access user guide (launches browser)}
control {number=5}{type=button}{role=restore}{display=Defaults}{tooltip=Resets the user interface and clears the log file}
control {number=6}{type=button}{role=logger}{display=Log}{tooltip=Log per interface}
value {control=0}{value= }{display=All advertising devices}{default=true}
value {control=0}{value=[00,00,00,00,00,00,0]}{display=Follow IRK}
value {control=1}{value=0}{display=Legacy Passkey}{default=true}
value {control=1}{value=1}{display=Legacy OOB data}
value {control=1}{value=2}{display=Legacy LTK}
value {control=1}{value=3}{display=SC LTK}
value {control=1}{value=4}{display=SC Private Key}
value {control=1}{value=5}{display=IRK}
value {control=1}{value=6}{display=Add LE address}
value {control=1}{value=7}{display=Follow LE address}
The Sniffer\Logs\log.txt file contains:
And when I launch Wireshark, I get the same result in log.txt as above - so it does seem to be launching the extcap plugin ok.30-Mar-2023 09:55:48 (-0400) INFO: --------------------------------------------------------
30-Mar-2023 09:55:48 (-0400) INFO: Software version: 4.1.1
30-Mar-2023 09:55:48 (-0400) INFO: Started PID 16260
30-Mar-2023 09:55:48 (-0400) INFO: Namespace(capture=False, extcap_interfaces=True, extcap_interface=None, extcap_dlts=False, extcap_config=False, extcap_capture_filter=None, fifo=None, extcap_control_in=None, extcap_control_out=None, extcap_version=None, device='', baudrate=None, only_advertising=False, only_legacy_advertising=False, scan_follow_rsp=False, scan_follow_aux=False, coded=False)
30-Mar-2023 09:55:48 (-0400) INFO: Opening serial port COM3
30-Mar-2023 09:55:49 (-0400) INFO: closing UART
30-Mar-2023 09:55:49 (-0400) INFO: Opening serial port COM3
30-Mar-2023 09:55:49 (-0400) INFO: Exiting PID 16260
Any suggestions?
