CircuitPython 8.0.5 Released!
danhalbert
Post by danhalbert »
From the GitHub release page:
This is CircuitPython 8.0.5, the latest bugfix revision of CircuitPython, and is a new stable release.
Notable changes to 8.0.5 since 7.3.0
See the CircuitPython 8.0.0 release notes for full information about changes in 8.0.x since 7.3.0.
Download from circuitpython.org
Firmware downloads are available from the downloads page on circuitpython.org. The site makes it easy to select the correct file and language for your board.
Installation
To install follow the instructions in the Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Documentation
Documentation is available in readthedocs.io.
Port status
CircuitPython has a number of "ports" that are the core implementations for different microcontroller families. Stability varies on a per-port basis. As of this release, these ports are consider stable:
  • atmel-samd: Microchip SAMD21, SAMx5x
  • cxd56: Sony Spresense
  • espressif: Espressif ESP32-S2
  • nrf: Nordic nRF52840, nRF52833
  • raspberrypi: Raspberry Pi RP2040
  • stm: ST STM32F4 chip family
These ports are considered alpha and will have bugs and missing functionality:
  • broadcom: Raspberry Pi boards such as RPi 4, RPi Zero 2W
  • espressif: ESP32, ESP32-S3, ESP32-C3
  • litex: fomu
  • mimxrt10xx: NXP i.MX RT10xxx
  • stm: ST non-STM32F4 chip families
Changes since 8.0.4
Fixes and enhancements
  • Prevent startup loop when settings.toml is edited. #7810. Thanks @jepler.
Build and infrastructure changes
  • Make build_board_info.py fetch files.json properly when it is larger than 1MB. #7728. Thanks @Neradoc and @dhalbert.
Known issues
  • ESP32-S3 has significant issues with I2C devices that sleep or use clock stretching. Retry operations on these devices as necessary, or use ESP32-S2 boards.
  • Espressif boards have ESP-IDF storage leaks and occasionally crash after extended WiFi use.
  • See https://github.com/adafruit/circuitpython/issues for other issues, including issues still to be addressed for:
Thank you to all who used, tested, and contributed since 8.0.4, including the contributors above, and many others on GitHub and Discord. Join us on the Discord chat to collaborate.
tultalk
Re: CircuitPython 8.0.5 Released!
Post by tultalk »
Hi: Does CircuitPython 8.0.5 run on Metro M7 RT1011? That board is not shown i the downloads.
Robert
danhalbert
FoamerGene
Post by FoamerGene »
I bought a pair of ItsyBitsy express M0's from your store a couple weeks ago. I found that the boot_out.txt reads CP 4.1.2, so I downloaded adafruit_drivers_2.5.0.0.ese and it appeared to run OK on my Win 7 box. But I don't know what to do with adafruit-circuitpython-itsy_m0_express_m0-en_US-8.0.5.uf2. The instructions are comingled with Win version aspects. Appreciations in advance for such help.
FoamerGene
danhalbert
Follow instructions starting here: https://learn.adafruit.com/welcome-to-c ... er-2977081
Basically, you double click, get the ITSYBOOT drive, and drag the .UF2 you downloaded to that drive. It will replace the version of CircuitPython that is on the board.
FoamerGene
Thanks Dan. I got much further, including files copied to the board and the Mu edior installed. But Mu said it can't find the board. I can see several files on it (including boot_out.txt that says 8.0.1) and it is in a mode of a double red(I think) blink of the RGB LED
Gene
