Reading RC servo pwm input on ESP32S3?
_joshu
Post by _joshu »
I'm trying to read a remote control PWM on an Unexpected Maker FeatherS3 (ESP32S3) in CircuitPython using pulseio.PulseIn. I never see anything, however. Am I barking up the wrong tree?
import pulseio
import board
print("starting")
pulse1 = pulseio.PulseIn(board.IO33)
while True:
    if pulse1.paused == True:
        pulse1.resume()
    if len(pulse1) > 0:
        print(list(pulse1))
        pulse1.clear()
mikeysklar
Re: Reading RC servo pwm input on ESP32S3?
Post by mikeysklar »
There were issues with PulseIn on the ESP32-S3 based chips.
Are you running the latest CircuitPython 8.x and libraries? The most recent patch went in on Jan 24th.
https://github.com/adafruit/circuitpython/issues/5909
https://github.com/adafruit/circuitpython/pull/5912
_joshu
Post by _joshu »
Yes, I am current: Adafruit CircuitPython 8.0.3 on 2023-02-23; FeatherS3 with ESP32S3
mikeysklar
Can you install the current latest stable CircuitPython 8.0.4 and latest libs?
This is probably an issue with pin number naming. IO33 might also go by
board.D5
If the problem persists you can reports issues with the CircuitPython github repo or Unexpected Maker discord. You just need to be current release before doing so.
_joshu
Post by _joshu »
Ok. I did this with a fresh board. Upgraded to 8.04 ("Adafruit CircuitPython 8.0.4 on 2023-03-15; FeatherS3 with ESP32S3"). No libs needed so not installed.
Wired it to a different pin by accident (board.D12), and this code does not ever emit anything. Otherwise identical code (different IO pin) works fine on 8.0.4 on a Pico. I guess I will open an issue.
import board, pulseio
p = pulseio.PulseIn(board.D12)
print(p.paused)
while True:
    if len(p) >0:
        print(p[0])
        p.clear()
mikeysklar
Okay, thank you for doing the update and trying another pin.
I don't have this board on hand to confirm, but it would be a good idea to do what I mentioned in the last post.
1) Ask if this is a known issue on the Unexpected Maker discord.
2) Open an issue with the CircuitPython github repo.
_joshu
Post by _joshu »
https://github.com/adafruit/circuitpython/issues/7817
I did ask on the discord at the beginning; they didn't think it was their issue.
mikeysklar
Thank you for opening the issue. It looks like you are getting some response and testers trying to reproduce the pwm input issue.
