rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
would set the time to last time you compiled the sketch but im 1 hr off (see serial console and txt file attached)
what am i doing wrong?
//2CO2_to_I2Cv4_loggerv4 04/03/2023
#include <Wire.h>
#include <SD.h>//sd card
#include <SPI.h>
#include <RTClib.h>// clock
// We will be using the I2C hardware interface on the Arduino in
// combination with the built-in Wire library to interface.
// Arduino analog input 5 - I2C SCL
// Arduino analog input 4 - I2C SDA
In this example we will do a basic read of the CO2 value and checksum verification.
For more advanced applications please see the I2C Comm guide.
//Global variable declaration
//int co2Addr =0;
int co2Addr1 = 0x69;// CO2 sensor 1
int co2Addr2 = 0x56;// CO2 sensor 2
int co2_value_1;
int co2_value_2;
// This is the default address:0x68 of the CO2 sensor, 7bits shifted left. for sensor board 2 changed to 0X6A
RTC_PCF8523 rtc;// clock on datalogger
// create file
File myFile;
//String Date,Time,CO2_1,CO2_2;
String Date,Time;
void setup() {//=============================================================
//start clock
rtc.begin();
//serial
Serial.begin(9600);
delay(2000);
//clock
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
while (1) delay(10);
if (! rtc.isrunning()) {
Serial.println("RTC is NOT running, let's set the time!");
// When time needs to be set on a new device, or after a power loss, the
// following line sets the RTC to the date & time this sketch was compiled
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
} // close clock
// SD card initialize
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
myFile = SD.open("data.txt", FILE_WRITE);
if (myFile) {
myFile.println( "Date, Time, CO2_1(ppm), CO2_2(ppm)) \r\n");
myFile.close();
else {
Serial.println("error opening data.txt");
Wire.begin ();
pinMode(13, OUTPUT); // address of the Arduino LED indicator
Serial.println("Application Note AN-102: Interface Arduino to two K-333");
}//==================================================== close setup Loop
// Function : int readCO2_1()
// Returns : CO2 Value upon success, 0 upon checksum failure
// Assumes : - Wire library has been imported successfully.
// - LED is connected to IO pin 13
// - CO2 sensor address is defined in co2_addr
int readCO2_1()
{//+++++++++++++++++++++++++++++++++++++++++++++++++ read CO2()function definition
co2_value_1 = 0; // We will store the CO2 value inside this variable.
digitalWrite(13, HIGH); // turn on LED
// On most Arduino platforms this pin is used as an indicator light.
/* Begin Write Sequence */
Wire.beginTransmission(0x69);
// Wire.beginTransmission(co2Addr1);
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
Wire.endTransmission();
/* End Write Sequence. */
We wait 10ms for the sensor to process our command.
The sensors's primary duties are to accurately
measure CO2 values. Waiting 10ms will ensure the
data is properly written to RAM
delay(10);
/* Begin Read Sequence */
Since we requested 2 bytes from the sensor we must
read in 4 bytes. This includes the payload, checksum,
and command status byte.
Wire.requestFrom(0x69, 4);
byte i = 0;
byte buffer[4] = {0, 0, 0, 0};
Wire.available() is not nessessary. Implementation is obscure but we leave
it in here for portability and to future proof our code
while (Wire.available())
buffer[i] = Wire.read();
i++;
/* End Read Sequence */
Using some bitwise manipulation we will shift our buffer
into an integer for general consumption
co2_value_1 = 0;
co2_value_1 |= buffer[1] & 0xFF;
co2_value_1 = co2_value_1 << 8;
co2_value_1 |= buffer[2] & 0xFF;
byte sum = 0; //Checksum Byte
sum = buffer[0] + buffer[1] + buffer[2]; //Byte addition utilizes overflow
if (sum == buffer[3])
// Success!
digitalWrite(13, LOW);
return co2_value_1;
else
// Failure!
Checksum failure can be due to a number of factors,
fuzzy electrons, sensor busy, etc.
return 0;
}//++++++++++++++++++++++++++++++++++++++++++ close the read CO2 function definition
// Function : int readCO2_2()
int readCO2_2()
co2_value_2 = 0; // We will store the CO2 value inside this variable.
Wire.beginTransmission(0x56);
Wire.write(0x22);
Wire.write(0x00);
Wire.write(0x08);
Wire.write(0x2A);
delay(10);
Wire.requestFrom(0x56, 4);
byte i = 0;
i++;
co2_value_2 = 0;
co2_value_2 |= buffer[1] & 0xFF;
co2_value_2 = co2_value_2 << 8;
co2_value_2 |= buffer[2] & 0xFF;
// Success!
return co2_value_2;
else
// Failure!
return 0;
//--------------------subroutines------------------------------------
void data_logging() {
// CO2_1 = String(co2_value_1);
// CO2_2 = String(co2_value_2);
// Data = CO2_1 + "," + CO2_2 ;
Serial.print("Save data: ");
// Serial.println(Data);
if (myFile) {
Serial.print("Writing to data.txt...");
//time stamp
DateTime now = rtc.now();
myFile.print(now.year(), DEC);
myFile.print('/');
myFile.print(now.month(), DEC);
myFile.print('/');
myFile.print(now.day(), DEC);
myFile.print(",");
myFile.print(now.hour(), DEC);
myFile.print(':');
myFile.print(now.minute(), DEC);
myFile.print(",");//delimeter between time and data
// myFile.println(Data);//ln adds carriage return
myFile.print(co2_value_1);
myFile.print(",");
myFile.println(co2_value_2);
myFile.close();
Serial.println("done.");
} else {
Serial.println();
void loop() {//#####################################################void loop
//once for sensor1 ADDRESS0x69//****************************************************************
// int co2Value = readCO2();// orig
co2_value_1 = readCO2_1()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
if (co2_value_1 > 0)
Serial.print("CO2 Value1: ");
Serial.println(co2_value_1);
else
Serial.println("Checksum failed / Communication failure");
delay(1000);
//********************************************************************done with CO2value1
//once for sensor2 ADDRESS0x56//****************************************************************
// orig location of dataloging but if placed here then it would dataloge before it had values of Co2 moved it to end
co2_value_2 = readCO2_2()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
if (co2_value_2 > 0)
Serial.print("CO2 Value2: ");
Serial.println(co2_value_2);
else
delay(1000);
// make a string for assembling the data to log:
data_logging();
delay(1000);//time between writting to sd card: delay(ms) 1000=1sec ; 900,000=15 min use this for final use 20,000 for testing
}//##############################################################################close loop
