Low memory available when using BME280
mromero
Post by mromero »
I have a project that reads 2 CO2 sensors and one BME280 sensor. I followed the example code for the BME280 sensor. I started with one program that wrote the BME280 output to SD card based on you example and i also wrote a separate program for the 2 CO2 sensors to write to SD card. All my components are adafruit except the CO2 sensors. I kind of wrote everything out explicitly and joined the two codes into one program. I get a low memory available error and for some reason. Also for some reason even though the write to sd file worked fine in my two separate programs it did not on the combined for some reason. I did not change the code to open the file.
#include <Wire.h>
#include <SD.h>//sd card
#include <SPI.h>
#include <RTClib.h>// clock
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1017)// orig 1013.25 the local is 1017
//Global variable declaration
int co2_value_1;
int co2_value_2;
RTC_PCF8523 rtc;// clock on datalogger
Adafruit_BME280 bme; // I2C for T, RH, altitude, atm press
// create file
File myFile;
//String Date,Time,CO2_1,CO2_2;
String Date,Time,Temperature, Pressure, Altitude, Humidity, Data;
void setup() {//============================================================= SETUP===============
  //start clock
  //serial
  Serial.begin(9600);
  delay(2000);
   //clock
 if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    Serial.flush();
    while (1) delay(10);
     if (! rtc.initialized() || rtc.lostPower()) {
     Serial.println("RTC is NOT running, let's set the time!");
    // When time needs to be set on a new device, or after a power loss, the
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  rtc.start();// added 4/4/2023 from pcf8523 code
  //bme280 sensor
  unsigned status;
  status = bme.begin();
   if (!status) {
    Serial.println("BME280 not connected properly. Check circuit!");
    while (1);
  // SD card initialize
  Serial.print("Initializing SD card...");
  if (!SD.begin(10)) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
  myFile = SD.open("data.txt", FILE_WRITE);
  if (myFile) {
    myFile.println( "Date, Time, CO2_1(ppm), CO2_2(ppm),Temperature(°C), Pressure(hPa), Altitude(m), Humidity(%) \r\n");
    myFile.close();
  else {
    Serial.println("error opening data.txt");
  Wire.begin ();
  pinMode(13, OUTPUT); // address of the Arduino LED indicator
  Serial.println("Application Note AN-102: Interface Arduino to two  K-333");
}//==================================================== close SETUP==========
//====================SUBROUTINES==================================
// Function : int readCO2_1()
// Returns : CO2 Value upon success, 0 upon checksum failure
// Assumes : - Wire library has been imported successfully.
// - LED is connected to IO pin 13
// - CO2 sensor address is defined in co2_addr
int readCO2_1()
{//+++++++++++++++++++++++++++++++++++++++++++++++++  read CO2()function definition
   co2_value_1 = 0;  // We will store the CO2 value inside this variable.
  digitalWrite(13, HIGH);  // turn on LED
  // On most Arduino platforms this pin is used as an indicator light.
  /* Begin Write Sequence */
  Wire.beginTransmission(0x69);
 // Wire.beginTransmission(co2Addr1);
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  Wire.endTransmission();
  /* End Write Sequence. */
    We wait 10ms for the sensor to process our command.
    The sensors's primary duties are to accurately
    measure CO2 values. Waiting 10ms will ensure the
    data is properly written to RAM
  delay(10);
  /* Begin Read Sequence */
    Since we requested 2 bytes from the sensor we must
    read in 4 bytes. This includes the payload, checksum,
    and command status byte.
  Wire.requestFrom(0x69, 4);
  byte i = 0;
  byte buffer[4] = {0, 0, 0, 0};
    Wire.available() is not nessessary. Implementation is obscure but we leave
    it in here for portability and to future proof our code
  while (Wire.available())
    buffer[i] = Wire.read();
    i++;
  /* End Read Sequence */
    Using some bitwise manipulation we will shift our buffer
    into an integer for general consumption
  co2_value_1 = 0;
  co2_value_1 |= buffer[1] & 0xFF;
  co2_value_1 = co2_value_1 << 8;
  co2_value_1 |= buffer[2] & 0xFF;
  byte sum = 0; //Checksum Byte
  sum = buffer[0] + buffer[1] + buffer[2]; //Byte addition utilizes overflow
  if (sum == buffer[3])
    // Success!
    digitalWrite(13, LOW);
    return co2_value_1;
  else
    // Failure!
      Checksum failure can be due to a number of factors,
      fuzzy electrons, sensor busy, etc.
    return 0;
}//++++++++++++++++++++++++++++++++++++++++++ close the read CO2 function definition
// Function : int readCO2_2()
int readCO2_2()
   co2_value_2 = 0;  // We will store the CO2 value inside this variable.
  Wire.beginTransmission(0x56);
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  Wire.requestFrom(0x56, 4);
  byte i = 0;
    i++;
  co2_value_2 = 0;
  co2_value_2 |= buffer[1] & 0xFF;
  co2_value_2 = co2_value_2 << 8;
  co2_value_2 |= buffer[2] & 0xFF;
    // Success!
    return co2_value_2;
  else
    // Failure!
    return 0;
//-------------------- data_logging() no values returned just save in sd card ----
void data_logging() {
  String Temperature = String(bme.readTemperature(), 2);
  String Pressure = String(bme.readPressure()/ 100.0F, 2);
  String Altitude = String(bme.readAltitude(SEALEVELPRESSURE_HPA), 2);
  String Humidity = String(bme.readHumidity(), 2);
  Data = Temperature + "," + Pressure + "," + Altitude + "," + Humidity ;
  Serial.print("Save data: ");
  Serial.println(Data);
  if (myFile) {
    Serial.print("Writing to data.txt...");
    //time stamp
    DateTime now = rtc.now();
    myFile.print(now.year(), DEC);
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.day(), DEC);
    myFile.print(",");
    myFile.print(now.hour(), DEC);
    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(",");//delimeter between time and data
    myFile.print(co2_value_1);
    myFile.print(",");
    myFile.print(co2_value_2);
    myFile.print(",");
    myFile.println(Data);//ln adds carriage return
    myFile.close();
    Serial.println("done.");
  } else {
  Serial.println();
//----------------------------------------------------End Subroutines-----------------------------------
void loop() {//##################################################### LOOP###############################
 //once for sensor1 ADDRESS0x69//********
 // int co2Value = readCO2();// orig
    co2_value_1 = readCO2_1()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
  if (co2_value_1 > 0)
    Serial.print("CO2 Value1: ");
    Serial.println(co2_value_1);
  else
    Serial.println("Checksum failed / Communication failure");
  delay(1000);
//once for sensor2 ADDRESS0x56//********
// orig location of dataloging but if placed here then  it would dataloge before it had values of Co2 moved it to end
  co2_value_2 = readCO2_2()*10;// what i was told to do. this gives half of what the dev kit prewired one reads.
  if (co2_value_2 > 0)
    Serial.print("CO2 Value2: ");
    Serial.println(co2_value_2);
  else
  delay(1000);
     // make a string for assembling the data to log:
     data_logging();
     delay(300000);//time between writting to sd card: delay(ms) 1000=1sec ; 900,000=15 min use this for final use 300,000 (5 min) for testing
}//##############################################################################CLOSE LOOP#########################[attachment=0]output file.png[/attachment]
output file.png (10.63 KiB) Viewed 132 times
dastels
Re: Low memory available when using BME280
Post by dastels »
Let's deal with the memory issue first.
1) what are you running this on?
2) at the end of the build output, what is the line that tells how much memory your program uses?
mromero
Post by mromero »
output file.png (8.92 KiB) Viewed 127 times
mromero
Post by mromero »
was able to lower the requiremnts a bit by changing the string operations to int .
I also tried 3x ways to make ther readCO2() a function where i passed 1 ( address 0x69) or a 2 ( address 0x59) but could not get it to work correctly hence the verbose way i coded it.
//2CO2_BME280_I2Cv4_loggerv6  04/05/2023
#include <Wire.h>
#include <SPI.h>
int co2_value_1;
int co2_value_2;
// create file
File myFile;
int Temperature, Pressure, Altitude, Humidity;
String Date,Time;
  //start clock
  //serial
  Serial.begin(9600);
  delay(2000);
   //clock
    Serial.flush();
  //bme280 sensor
  unsigned status;
   if (!status) {
    while (1);
    while (1);
  if (myFile) {
    myFile.close();
  else {
  Wire.begin ();
 // Serial.println("Application Note AN-102: Interface Arduino to two  K-333");
int readCO2_1()
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  byte i = 0;
    i++;
  co2_value_1 = 0;
    // Success!
    return co2_value_1;
  else
    // Failure!
    return 0;
int readCO2_2()
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  byte i = 0;
    i++;
  co2_value_2 = 0;
    // Success!
    return co2_value_2;
  else
    // Failure!
    return 0;
  int Temperature = (bme.readTemperature(), 2);
  int Pressure = (bme.readPressure()/ 100.0F, 2);
 // int Altitude = int(bme.readAltitude(SEALEVELPRESSURE_HPA), 2);
  int Humidity = (bme.readHumidity(), 2);
 // String Data = Temperature + "," + Pressure + "," + Altitude + "," + Humidity ;
//  Serial.print("Save data: ");
//  Serial.println(Data);
  if (myFile) {
    //time stamp
    myFile.print('/');
    myFile.print('/');
    myFile.print(",");
    myFile.print(':');
    myFile.print(",");
    myFile.print(",");
    myFile.print(Temperature);
    myFile.print(",");
    myFile.print(Pressure);
    myFile.print(",");
    myFile.print(Humidity);
    myFile.print(",");
    myFile.println( );//ln adds carriage return
    myFile.close();
  } else {
  Serial.println();
  else
  delay(1000);
  else
  delay(1000);
     data_logging();
     delay(120000);//time between writting to sd card: delay(ms) 1000=1sec ; 900,000=15 min use this for final use 120,000 (2 min) for testing
output file.png (7.68 KiB) Viewed 127 times
mromero
Post by mromero »
the output of the code is incorrect
output file.png (13.74 KiB) Viewed 127 times
mromero
Post by mromero »
ok got the output to work correctly but still get low memory and still need to add a relay which will have one more variable. Is there something else i can do to lower the memory usage in the Global variables
#include <Wire.h>
#include <SPI.h>
int co2_value_1;
int co2_value_2;
// create file
File myFile;
String Date,Time;
  //start clock
  //serial
  Serial.begin(9600);
  delay(2000);
   //clock
    Serial.flush();
  //bme280 sensor
  unsigned status;
   if (!status) {
    while (1);
    while (1);
  if (myFile) {
    myFile.close();
  else {
  Wire.begin ();
int readCO2_1()
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  byte i = 0;
    i++;
  co2_value_1 = 0;
    // Success!
    return co2_value_1;
  else
    // Failure!
    return 0;
int readCO2_2()
  Wire.write(0x22);
  Wire.write(0x00);
  Wire.write(0x08);
  Wire.write(0x2A);
  delay(10);
  byte i = 0;
    i++;
  co2_value_2 = 0;
    // Success!
    return co2_value_2;
  else
    // Failure!
    return 0;
//  int Temperature = (bme.readTemperature(), 2);
//  Serial.print(Temperature());
//  Serial.print(",");
//  Serial.print(bme.readTemperature());
//  int Pressure = (bme.readPressure()/ 100.0F, 2);
//   Serial.print(bme.readPressure());
// // int Altitude = int(bme.readAltitude(SEALEVELPRESSURE_HPA), 2);
//  int Humidity = (bme.readHumidity(), 2);
//     Serial.print(bme.readHumidity());
  if (myFile) {
    //time stamp
    myFile.print('/');
    myFile.print('/');
    myFile.print(",");
    myFile.print(':');
    myFile.print(",");
    myFile.print(",");
    myFile.print(bme.readTemperature());
    myFile.print(",");
    myFile.print(bme.readPressure()/100.0F);
    myFile.print(",");
    myFile.print(bme.readHumidity());
    myFile.print(",");
    myFile.close();
  } else {
  Serial.println();
  else
  delay(1000);
  else
  delay(1000);
     data_logging();
output file.png (16.54 KiB) Viewed 124 times
dastels
Post by dastels »
It looks like it will be a constant struggle. You could move to a more advanced processor with more memory. The code is unlikely to need any changes, which is an advantage of the Arduino platform.
