I have a KB2040 flashed as a keyboard using QMK. I am working on making a mechanical keyboard that has two modes:
- wireless, where the keyboard feeds its output to an onboard terminal-only Raspberry Pi Zero (the RPiZero's D+ and D- test pads are wired to the KB2040's D+ and D- pins)
- wired, where the keyboard feeds its output to the device connected by a USB cable
I have both modes working successfully when I power on into either. Here's the sequence of behavior I want to understand better:
1. Boot system in wireless mode
2. KB2040 successfully writes keycodes to RPiZero
3. Plug in USB cable to KB2040 connecting it to my desktop
4. KB2040 successfully writes keycodes to my desktop
- Note, it does not double write (output keycodes to both the onboard RPiZero and the connected device) and it would be an acceptable outcome if it double writes
5. Unplug the USB cable
6. KB2040 no longer writes keycodes to RPiZero
Interestingly, the KB2040 continues to not write on the RPiZero even after restarting the KB2040 by itself. I have to restart the RPiZero before it will start reading the keycodes again.
Help?
KB2040 - D+/D- pins change behavior after plugging in USB cable
- ebyerly
- ebyerly
Re: KB2040 - D+/D- pins change behavior after plugging in USB cable
Two addendums:
- this behavior occurs whether the KB2040 is connected to a USB cable that uses the data lines _or_ a USB cable that is handling solely power delivery
- this behavior smells like some flavor of "USB standard doesn't support multiple readers / you need a USB hub IC intermediating the KB2040 and the RPiZero/external cable", but I want to narrow it down as much as possible
