Hi! I bought an Adalogger M0, and I want to integrate a RFM95W module with it. I have tried to use the example provided for the LoRa M0 feather on the Adafruit website, and the RFM95W example (but they are pretty much the same) and i have an error regarding "RHutil/atomic.h". I don't understand what is the problem, hopefully i have something poorly installed and there isn't a compatibility issue ;(
In file included from /Users/.../Documents/Arduino/libraries/SparkFun_RadioHead_Arduino_Library-master/src/RHGenericDriver.h:9,
from /Users/.../Documents/Arduino/libraries/SparkFun_RadioHead_Arduino_Library-master/src/RHSPIDriver.h:9,
from /Users/.../Documents/Arduino/libraries/SparkFun_RadioHead_Arduino_Library-master/src/RH_RF95.h:15,
from /Users/.../Documents/Arduino/projects/ProMicro/ProMicro_LoRa_Transmit_copy_20230412203245/ProMicro_LoRa_Transmit_copy_20230412203245.ino:10:
/Users/.../Documents/Arduino/libraries/SparkFun_RadioHead_Arduino_Library-master/src/RadioHead.h:616:12: fatal error: RHutil/atomic.h: No such file or directory
616 | #include <RHutil/atomic.h>
compilation terminated.
exit status 1
Compilation error: exit status 1
RadioHead Library Feather M0 Adalogger
- mikeysklar
Re: RadioHead Library Feather M0 Adalogger
You should probably be using the Adafruit RadioHead library. Install it via the library manager not via github so it will pull in the other dependencies.
