Seriel1 not declared basic uart_rvc
Oeuf
Posts: 1 Joined: Tue Apr 18, 2023 12:30 pm
Post
by Oeuf » Tue Apr 18, 2023 1:07 pm
Hey, new member here, I recently tried out the UART-RVC setup on the Arduino UNO shell, and when I tried to run it gave me this error message:
C:\Users\User\BANNED\Documents\Arduino\uart_rvc\uart_rvc.ino: In function 'void setup()':
uart_rvc:17:3: error: 'Serial1' was not declared in this scope
Serial1.begin(115200); // This is the baud rate specified by the datasheet
C:\Users\User\BANNED\Documents\Arduino\uart_rvc\uart_rvc.ino:17:3: note: suggested alternative: 'Serial'
Serial
exit status 1
The code is :
#include <Adafruit_BNO08x_RVC.h>
/* Test sketch for Adafruit BNO08x sensor in UART-RVC mode */
Adafruit_BNO08x_RVC rvc = Adafruit_BNO08x_RVC();
// Wait for serial monitor to open
Serial.begin(115200);
while (!Serial)
delay(1);
Serial.println("Adafruit BNO08x IMU - UART-RVC mode");
while (!Serial1)
delay(10);
if (!rvc.begin(&Serial1)) { // connect to the sensor over hardware serial
Serial1.println("Could not find BNO08x!");
while (1)
delay(10);
Serial.println("BNO08x found!");
BNO08x_RVC_Data heading;
if (!rvc.read(&heading)) {
return;
Serial.println();
Serial.println(F("---------------------------------------"));
Serial.println(F("Principal Axes:"));
Serial.print(F("Yaw: "));
Serial.print(heading.yaw);
Serial.print(F("\tPitch: "));
Serial.print(heading.pitch);
Serial.print(F("\tRoll: "));
Serial.println(heading.roll);
Serial.println(F("Acceleration"));
Serial.print(F("X: "));
Serial.print(heading.x_accel);
Serial.print(F("\tY: "));
Serial.print(heading.y_accel);
Serial.print(F("\tZ: "));
Serial.println(heading.z_accel);
// delay(200);
The website source:
https://learn.adafruit.com/adafruit-9-d ... or-arduino
Does it mean that: The UNO shell is incapable? Or there is something missing in the code?
adafruit_support_carter
Posts: 29150 Joined: Tue Nov 29, 2016 2:45 pm
Post
by adafruit_support_carter » Tue Apr 18, 2023 1:27 pm
For the UNO, will need to use SoftwareSerial.
https://docs.arduino.cc/learn/built-in- ... are-serial
Try this wiring:
UNO 5V to BNO VIN
UNO GND to BNO GND
UNO #2 to BNO SDA
BNO P0 to BNO 3Vo (this sets RVC mode)
And this sketch:
#include <SoftwareSerial.h>
#include "Adafruit_BNO08x_RVC.h"
const byte rxPin = 2;
const byte txPin = 3;
// Set up a new SoftwareSerial object
SoftwareSerial mySerial (rxPin, txPin);
while (!Serial)
delay(10);
mySerial.begin(115200); // This is the baud rate specified by the datasheet
if (!rvc.begin(&mySerial)) {
Serial.println("Could not find BNO08x!");
while (1)
delay(10);
return;
Serial.println();
// delay(200);
gammaburst
Posts: 1015 Joined: Thu Dec 31, 2015 12:06 pm
Post
by gammaburst » Tue Apr 18, 2023 2:36 pm
That SoftwareSerial sketch will kinda run on an Uno, but you'll probably see some data glitches and less than the full 100 readings per second.
The Uno has has only one hardware UART, and it's connected to the USB interface.
You'll have better luck using a different processor that has an extra hardware UART.
