Adafruit PWM/Servo Shield and ESC
Lestat75
Post by Lestat75 »
I'm getting crazy with the Adafruit 16-Channel 12-bit PWM/Servo Shield and ESC connected to a brushless motor.
The connections are:
- Arduino powered by USB (Desktop PC)
- Shield I2C address changed to 0x41 with soldering
- ESC connected to the Shield connected on Port 4
- Shield receive power from the ESC directly
- The ESC receive power from a LiPo 3s (11.1V 2.2Ah)
The issue is that the motor sometime works, sometime doesn't work
I think I'm missing some "init" command, but really I do not know.
Here the code:
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm;
#define PWM_MAX_REVERSE 100
#define PWM_MAX_FORWARD 500
#define PWM_ZERO PWM_MAX_REVERSE + ((PWM_MAX_FORWARD-PWM_MAX_REVERSE)/2)
#define PWMFREQ  50
void setup()
  pwm = Adafruit_PWMServoDriver(0x41);
  pwm.begin();
  pwm.setPWMFreq(PWMFREQ);
  pwm.setPWM(4,0,PWM_ZERO);
  delay(2000);
  pwm.setPWM(4,0, PWM_MAX_FORWARD );
  delay(2000);
  pwm.setPWM(4,0,PWM_MAX_REVERSE);
  delay(2000);
  delay(2000);
void loop()
Reason: Add code tags
Re: Adafruit PWM/Servo Shield and ESC
You didn't mention the type of Arduino you are using. Some ESCs don't work reliably with 3.3v control signals. So if you are using an Arduino with a 3.3v processor chip, that could be the issue.
I have seen some ESCs that require a specific initialization signal. You would need to check the specifications for your ESC about that.
Lestat75
Post by Lestat75 »
i am using an Arduino Mega
The Mega is 5v, so that should be OK. If you post some clear photos of the front and back of the board we can look for any assembly issues.
Lestat75
Post by Lestat75 »
I solved it.
The ESC needs to be "calibrated" setting PWMs to the min and max value
Good to hear you found the solution. Thank for the follow-up.
