Security Access tuner replica from alien isolation
knoxvilles_Joker
Post by knoxvilles_Joker »
This used all the available space on an arduino micro. Yes I could spend two months or more cleaning up the code and optomizing it so I could accuratize it more, but I am running out of time.
the 3d files:
https://www.thingiverse.com/thing:5217302
The charger and board board:
https://www.adafruit.com/product/2465
The top push buttons:
https://www.amazon.com/gp/product/B0752 ... UTF8&psc=1
on off rocker switch:
https://www.amazon.com/gp/product/B07Y1 ... YMCKV&th=1
the slide potentiometer:
https://www.digikey.com/en/products/det ... ncQAvD_BwE
THe turn potentiometer:
https://www.digikey.com/en/products/det ... 0K/4780740
the screen:
https://www.adafruit.com/product/2478
/*Libraries provided by adafruit written by Lady Ada Fried.
 *Please stick to adafruit products as chinese knock offs are very,
 *very, very, very, very, very problematic.
 * code for bar courtesy of:
 * https://forum.arduino.cc/t/tft-progress-bar-wont-go-back-down/989189
 * some code pulled from isolation motion tracker pulled from:
 * https://www.instructables.com/Arduino-Motion-Tracker-From-Alien-Isolation/?fbclid=IwAR2P0H8tUwBisNGaP4C2vccz-fbBOlxxfdm8EIJJEHgAZnKOtgemeBjAZ3M
 * help found on arduino forums at https://arduino.cc
// Include the Bounce2 library found here :
// https://github.com/thomasfredericks/Bounce2
#include <avr/wdt.h>
#include <Bounce2.h>
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
#include <LcdProgressBar.h>
#include <LiquidCrystal.h>
// For the Adafruit shield, these are the default.
// USE hardware SPI pins.
// For Micro those pins are CIPO/MISO=D14, COPI/MOSI=D16, SCK=D15
#define TFT_DC 9
#define TFT_CS 10
// the colors are in a RGB565 format, so to get it you first need to grab it as a RGB888 and convert
//go here
//https://imagecolorpicker.com/en
//then here
//http://www.barth-dev.de/online/rgb565-color-picker/
// Assign human-readable names to some common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#define DARKGREEN 0x03E0
#define OLIVE 0x7BE0
#define GREENYELLOW 0xAFE5
#define TEAL 0x263F
// button pins
//22 is a4, 23 is a5 on micro.
#define BUTTON_PIN_1 A5
#define BUTTON_PIN_2 A4
// pot pins are pins 14(a0) and 15(a1)
Bounce debouncer1 = Bounce();
Bounce debouncer2 = Bounce();
enum { initial,
       bar1test,
       bar1passed1,
       bar2test,
       bar2passed1,
       bar3test,
       bar3passed1,
       gamewon,
       gamelost };
unsigned char barstate = bar1test;
//global integer declarations
// arguments exist against global variables, however, they are nice if you use integers across functions
int rangelow;
int rangehigh;
int g1low = 80;
int g1high = 80;
int center;
int detect = 0;
int render = 0;
int b1 = 0;
int b2 = 0;
//invokation for the adafruit TFT
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);  //, TFT_MOSI, TFT_CLK, TFT_MISO);
  pinMode(A0, INPUT);
  tft.begin();
  tft.fillScreen(BLACK);
  tft.setRotation(1);  //this sets 0,0 as the top left corner
  boot1();
  boot2();
  tft.setRotation(1);
  // button initialization
  pinMode(BUTTON_PIN_1, INPUT_PULLUP);
  debouncer1.attach(BUTTON_PIN_1);
  debouncer1.interval(5);
  pinMode(BUTTON_PIN_2, INPUT_PULLUP);
  debouncer2.attach(BUTTON_PIN_2);
  debouncer2.interval(25);
  // sets up random number generator for game1 to game 2 transition
  randomSeed(analogRead(A3));
  center = random(150, 950);
  rangelow = center - g1low;
  rangehigh = center + g1high;
  // comment out the bottom two if else statements and replace them with the below line to aid in calibrating your setup
  // calibration();
  if (rangelow < analogRead(A0) && analogRead(A0) < rangehigh) {
    game2();
  } else {  // this is game1 and has to be here for the detection count to register properly.
    debouncer1.update();
    debouncer2.update();
    int value1 = debouncer1.read();
    int value2 = debouncer2.read();
    int myHeight = tft.height();
    int myWidth = tft.width();
    // this is a delayed screen rerender
    int render1;
    render1++;
    delay(10);
    if (render1 == 2) {
      render1++;
    if (render1 == 40) { render1 = 0; }
    //I ended up having to separate out remaps for each side of the slider bar
    int bordw = map(analogRead(A0), 0, 1023, 0, 1023);
    int bordt = map(analogRead(A0), 0, 256, 0, myWidth);
    int bordrh = map(analogRead(A0), 256, 512, 0, myHeight);
    int bordb = map(analogRead(A0), 512, 768, myWidth, 0);
    int bordlh = map(analogRead(A0), 768, 1023, myHeight, 0);
    tft.fillRect(bordt, 0, 20, 5, WHITE);
    tft.fillRect(myWidth - 5, bordrh, 5, 20, WHITE);
    tft.fillRect(bordb, (myHeight - 5), 20, 5, WHITE);
    tft.fillRect(0, bordlh, 5, 20, WHITE);
    delay(10);
    tft.fillRect(0, 0, 5, myHeight, BLACK);
    tft.fillRect(0, 0, myWidth, 5, BLACK);
    tft.fillRect(myWidth - 5, 0, 5, myHeight, BLACK);
    tft.fillRect(0, (myHeight - 5), myWidth, 5, BLACK);
    // center box
    // yellow border
    tft.drawRect(myWidth * 2 / 16 - 8, myHeight * 4 / 12, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    tft.drawRect(myWidth * 2 / 16 - 7, myHeight * 4 / 12 - 1, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    tft.drawRect(myWidth * 2 / 16 - 6, myHeight * 4 / 12 - 2, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    tft.drawRect(myWidth * 2 / 16 - 5, myHeight * 4 / 12 - 3, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    tft.drawRect(myWidth * 2 / 16 - 4, myHeight * 4 / 12 - 4, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    tft.drawRect(myWidth * 2 / 16 - 3, myHeight * 4 / 12 - 5, myWidth * 13 / 16 + 12, myHeight * 4 / 12, YELLOW);
    // text segments
    tft.setCursor(myWidth * 2 / 16, myHeight * 5 / 12 - 10);
    tft.setTextColor(WHITE);
    tft.setTextSize(2);
    tft.print("INCORRECT CODE");
    tft.setCursor(myWidth * 2 / 16, myHeight * 7 / 12 - 10);
    tft.setTextSize(2);
    tft.print("SYSTEM DETECTIONS");
    tft.setCursor(myWidth * 13 / 16, myHeight * 7 / 12 - 10);
    tft.setTextSize(2);
    tft.print(detect);
    tft.setCursor(myWidth * 13 / 16 + 12, myHeight * 7 / 12 - 10);
    tft.setTextSize(2);
    tft.print("/3");
    // this is a rerender section
    if (value1 == 0) { b1++; }
    if (b1 == 5) {
      b1++;
    if (b1 == 7) { b1 = 0; }
    // this is for the static effect
    //row1
    tft.fillRect(myWidth * 1 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 1 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16 + 10, myHeight * 1 / 12 + 10, 10, 10, WHITE);
    //row2
    tft.fillRect(myWidth * 1 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 2 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16 + 10, myHeight * 2 / 12 + 10, 10, 10, WHITE);
    //half row3
    tft.fillRect(myWidth * 1 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 3 / 12, 10, 10, WHITE);
    //rows
    tft.fillRect(myWidth * 1 / 16, myHeight * 4 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16, myHeight * 5 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16, myHeight * 6 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16, myHeight * 7 / 12, 10, 10, WHITE);
    //row8
    tft.fillRect(myWidth * 1 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 1 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 8 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16 + 10, myHeight * 8 / 12 + 10, 10, 10, WHITE);
    //row9
    tft.fillRect(myWidth * 1 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 2 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 4 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 6 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 8 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 10 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 12 / 16,myHeight * 9 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 9 / 12, 20, 20, WHITE);
    //tft.fillRect(myWidth * 14 / 16,myHeight * 9 / 12,20,20,WHITE);
    //row10
    tft.fillRect(myWidth * 1 / 16, myHeight * 10 / 12, 10, 10, WHITE);
  //  tft.fillRect(myWidth * 1 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 2 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 3 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 10 / 12, 10, 10, WHITE);
  //  tft.fillRect(myWidth * 4 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 5 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 6 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 7 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 8 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 9 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 10 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 11 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 12 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 13 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 10 / 12, 10, 10, WHITE);
    tft.fillRect(myWidth * 14 / 16 + 10, myHeight * 10 / 12 + 10, 10, 10, WHITE);
    //row11
    //tft.fillRect(myWidth * 1 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 2 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 3 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 4 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 5 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 6 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 7 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 8 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 9 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 10 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 11 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 12 / 16, myHeight * 11 / 12, 20, 15, WHITE);
    //tft.fillRect(myWidth * 13 / 16,myHeight * 11 / 12,20,20,WHITE);
    tft.fillRect(myWidth * 14 / 16, myHeight * 11 / 12, 20, 15, WHITE);
  // declarations for buttons
  delay(20);
void calibration() {
  int bar = map(analogRead(A0), 0, 1023, 0, 308);
  tft.fillRect(6, 80, bar, 44, RED);
  tft.fillRect(bar, 80, 308 - bar, 44, BLACK);
  tft.fillRect(0, 20, myWidth, 5, BLACK);
  // draws pot number reading
  tft.setCursor(80, 40);
  tft.setTextColor(RED);
  tft.setTextSize(3);
  tft.println(analogRead(A0));
  // draws pot 2 number reading
  tft.setCursor(160, 40);
  tft.setTextSize(3);
  tft.println(analogRead(A1));
  // clears button status
  tft.fillRect(80, 140, 100, 30, BLACK);
  tft.fillRect(80, 180, 100, 30, BLACK);
  // add rendering pause
  delay(100);
  // clears drawings
  tft.fillRect(bar, 20, 20, 5, WHITE);
  tft.fillRect(80, 40, 200, 30, BLACK);
  //math for range sweetspot logic
    tft.fillRect(230, 40, 20, 20, OLIVE);
  } else {
    tft.fillRect(230, 40, 20, 20, BLACK);
  // draws button 2 status
  tft.setCursor(160, 140);
  tft.setTextSize(3);
  tft.println(value2);
  // draws button 1 status
  tft.setCursor(80, 140);
  tft.setTextColor(OLIVE);
  tft.setTextSize(3);
  tft.println(value1);
  // draws pot 2 status
  tft.setCursor(160, 180);
  tft.setTextSize(3);
  tft.println(rangelow);
  // draws pot 1 status
  tft.setCursor(80, 180);
  tft.setTextSize(3);
  tft.println(rangehigh);
  // clears text
void boot1() {
  byte progress = myWidth / 8;
  int progress1;
  tft.setCursor(30, 10);
  tft.setTextColor(GREEN);
  tft.setTextSize(6);
  tft.println("SEEGSON");
  tft.drawRect(myWidth * 2 / 16, myHeight * 3 / 5, myWidth * 12 / 16 - 5, 50, GREEN);
  for (int i = 0; i < 40; i++) {
    tft.fillRect(myWidth * 2 / 16, myHeight * 3 / 5, progress, 50, GREEN);
    tft.setTextSize(2);
    tft.setCursor(myWidth * 4 / 16, myHeight * 5 / 12);
    tft.print("Progress  ");
    tft.setTextSize(2);
    tft.setCursor(myWidth * 5 / 8, myHeight * 5 / 12);
    progress1 = progress * 17 / 40;
    tft.print(progress1);
    delay(5);
    tft.fillRect(myWidth * 9 / 16, myHeight * 5 / 12, myHeight * 5 / 12, 20, BLACK);
    progress += 5;
void boot2() {
  tft.setCursor(myWidth * 3 / 16, myHeight * 9 / 12);
  tft.setTextSize(3);
  tft.print("Please wait");
  //draws verticle line
  tft.drawRect(myWidth / 2, 5, 2, 65, WHITE);
  delay(200);
  tft.drawRect(myWidth / 2, 5, 2, 65, BLACK);
  // draws 45 degree line
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 6, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 9, WHITE);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 5, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 10, WHITE);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 4, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 11, WHITE);
  delay(200);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 6, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 9, BLACK);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 5, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 10, BLACK);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 3 / 12 + 4, myWidth * 9 / 16 + 10, myHeight * 1 / 12 - 11, BLACK);
  // draws horizontal line
  tft.fillRect(myWidth * 6 / 16 + 5, myHeight * 2 / 12 - 5, 70, 2, WHITE);
  delay(200);
  tft.fillRect(myWidth * 6 / 16 + 5, myHeight * 2 / 12 - 5, 70, 2, BLACK);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 9, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 6, WHITE);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 10, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 5, WHITE);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 11, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 4, WHITE);
  delay(200);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 9, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 6, BLACK);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 10, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 5, BLACK);
  tft.drawLine(myWidth * 7 / 16 - 10, myHeight * 1 / 12 - 11, myWidth * 9 / 16 + 10, myHeight * 3 / 12 + 4, BLACK);
  delay(200);
  delay(200);
  delay(200);
  delay(200);
void game2() {
  // declare variables for function
  int estcon;
  int senpak;
  int ovrpak;
  // sets base text for game
  tft.setCursor(myWidth * 3 / 16, myHeight * 1 / 12);
  tft.setTextSize(2);
  tft.print("SYSTEM OVERRIDE");
  tft.setCursor(myWidth * 4 / 16 - 10, myHeight * 11 / 12);
  tft.setTextSize(1);
  tft.print("SECURITY FREQUENCY MATCH");
  tft.setCursor(myWidth * 4 / 16, myHeight * 12 / 12 - 10);
  tft.setTextSize(1);
  tft.print("V2.34 SYSTEM TEST");
  //calibrate2(); //turn this on ifyou need to verify you have wiring and settings correct.
  // the big minigame border
  tft.drawRect(3, myHeight * 3 / 12, myWidth - 9, myHeight * 6 / 12, WHITE);
  tft.drawRect(6, myHeight * 3 / 12, myWidth - 15, myHeight * 6 / 12, WHITE);
  int pass1;
  // this rerenders based on button presses
  //  int detect;
  switch (barstate) {
    case bar1test:
      bar1();
      if (value2 == 0 && 220 < analogRead(A1) && analogRead(A1) < 440) {
        barstate = bar1passed1;
        break;
      if (value2 == 0 && analogRead(A1) > 440) {
        barstate = gamelost;
        detect++;
        break;
      if (value2 == 0 && 220 > analogRead(A1)) {
        detect++;
        break;
      break;
    case bar1passed1:
      passedbar1();
      bar2();
      barstate = bar2test;
      break;
    case bar2test:
      passedbar1();
      bar2();
      if (value2 == 0 && 140 < analogRead(A1) && analogRead(A1) < 280) {
        barstate = bar2passed1;
        break;
      if (value2 == 0 && analogRead(A1) > 280) {
        detect++;
        break;
      if (value2 == 0 && 140 > analogRead(A1)) {
        detect++;
        break;
      if (value2 == 0 && detect == 3) {
        break;
      break;
    case bar2passed1:
      passedbar1();
      passedbar2();
      bar3();
      barstate = bar3test;
      break;
    case bar3test:
      passedbar1();
      passedbar2();
      bar3();
      if (value2 == 0 && 720 > analogRead(A1)) {
        detect++;
        break;
      if (value2 == 0 && analogRead(A1) > 870) {
        detect++;
        break;
      if (value2 == 0 && 720 < analogRead(A1) && analogRead(A1) < 870) {
        barstate = bar3passed1;
        break;
      break;
    case bar3passed1:
      passedbar1();
      passedbar2();
      passedbar3();
      barstate = gamewon;
      break;
    case gamewon:
      tft.fillScreen(GREEN);
      // center box   yellow border
      // this fills the center box black
      tft.fillRect(myWidth * 2 / 16 - 2, myHeight * 4 / 12 - 0, myWidth * 13 / 16 + 5, myHeight * 4 / 12 - 5, BLACK);
      // text segments
      tft.setTextSize(2);
      tft.print("Code Accepted");
      tft.setTextSize(2);
      tft.setTextSize(2);
      tft.print(detect);
      tft.setTextSize(2);
      tft.print("/3");
      delay(2000);
      tft.fillScreen(GREENYELLOW);
      // text segments
      tft.setCursor(myWidth * 4 / 16, myHeight * 6 / 12 - 10);
      tft.setTextColor(TEAL);
      tft.setTextSize(2);
      tft.print("Acces Granted");
      delay(2000);
      //   This is a software reset call via software functions built into the chipset.
      softwareReset(WDTO_60MS);
      break;
    case gamelost:
      // text segments
      tft.setTextSize(2);
      tft.setTextSize(2);
      tft.setTextSize(2);
      tft.print(detect);
      tft.setTextSize(2);
      tft.print("/3");
      tone(12, 500, 70);
      delay(1500);
      //      This is the logic for the counter on detection attempts/failures.  It resets once it reaches 3.
      tft.fillScreen(TEAL);
      if (detect <= 2) {
        break;
      if (detect >= 3) {
        break;
      break;
  // this is a rerender section based on pushing a button
  if (b1 == 5) {
    b1++;
  if (b1 == 7) { b1 = 0; }  //
  //  This delays the redrawing of the entire screen
  render++;
  delay(10);
  if (render == 2) {
    render++;
  if (render == 70) { render = 0; }
void bar1() {
  int estcon;
  // bar 1 override takes reading from slider pot and draws the bar
  tft.setCursor(20, myHeight * 3 / 12 + 5);
  tft.setTextSize(1);
  tft.print("Establishing Connection");
  estcon = map(analogRead(A1), 0, 1023, 10, 295);
  tft.fillRect(estcon, myHeight * 4 / 12, 5, 15, WHITE);
  // redraws left of the slider
  tft.fillRect(9, myHeight * 4 / 12, estcon - 1, 15, TEAL);
  // redraws right of the slider
  tft.fillRect(estcon + 12, myHeight * 4 / 12, myWidth - estcon - 30, 15, TEAL);
  // these are the static vertical lines on the bar
  tft.drawRect(9, myHeight * 4 / 12, myWidth - 30, 15, WHITE);
  tft.fillRect(myWidth - 50, myHeight * 4 / 12, 30, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16 - 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16 + 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 5 / 16 - 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 5 / 16, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 5 / 16 + 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 6 / 16 - 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 6 / 16, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 6 / 16 + 10, myHeight * 4 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 7 / 16, myHeight * 4 / 12, 4, 15, WHITE);
void bar2() {
  int senpak;
  // bar 2 override takes reading from slider pot and draws the bar
  tft.setCursor(20, myHeight * 5 / 12 + 5);
  tft.setTextSize(1);
  tft.print("Sending Packets");
  senpak = map(analogRead(A1), 0, 1023, 10, 295);
  tft.fillRect(senpak, myHeight * 6 / 12, 5, 15, WHITE);
  tft.fillRect(9, myHeight * 6 / 12, senpak - 1, 15, TEAL);
  tft.fillRect(senpak + 12, myHeight * 6 / 12, myWidth - senpak - 30, 15, TEAL);
  // draws lines
  tft.drawRect(9, myHeight * 6 / 12, myWidth - 30, 15, WHITE);
  tft.drawRect(myWidth * 3 / 16 - 10, myHeight * 6 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 3 / 16 + 10, myHeight * 6 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 3 / 16, myHeight * 6 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16 - 10, myHeight * 6 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16, myHeight * 6 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 4 / 16 + 10, myHeight * 6 / 12, 4, 15, WHITE);
void bar3() {
  int ovrpak;
  //bar 3
  tft.setCursor(20, myHeight * 7 / 12 + 5);
  tft.setTextSize(1);
  tft.print("Overriding Protocol");
  ovrpak = map(analogRead(A1), 0, 1023, 10, 295);
  tft.fillRect(ovrpak, myHeight * 8 / 12, 5, 15, WHITE);
  tft.fillRect(9, myHeight * 8 / 12, ovrpak - 1, 15, TEAL);
  tft.fillRect(ovrpak + 12, myHeight * 8 / 12, myWidth - ovrpak - 30, 15, TEAL);
  // draws lines
  tft.drawRect(9, myHeight * 8 / 12, myWidth - 30, 15, WHITE);
  tft.drawRect(myWidth * 11 / 16 - 10, myHeight * 8 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 11 / 16 + 10, myHeight * 8 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 11 / 16, myHeight * 8 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 12 / 16 - 10, myHeight * 8 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 12 / 16, myHeight * 8 / 12, 4, 15, WHITE);
  tft.drawRect(myWidth * 12 / 16 + 10, myHeight * 8 / 12, 4, 15, WHITE);
void calibrate2() {
  // calibration testing
  tft.setCursor(myWidth * 4 / 16, myHeight * 10 / 12 - 10);
  tft.setTextSize(1);
  tft.setCursor(myWidth * 6 / 16, myHeight * 10 / 12 - 10);
  tft.setTextSize(1);
  tft.setCursor(myWidth * 8 / 16, myHeight * 10 / 12 - 10);
  tft.setTextSize(1);
  delay(10);
  tft.fillRect(myWidth * 4 / 16, myHeight * 10 / 12 - 10, 100, 20, TEAL);
  // end calibration testing section
void passedbar1() {
  // renders static bar once bar 1 passed checks
  tft.drawRect(20, myHeight * 3 / 12 + 5, 200, 15, TEAL);
  tft.setTextSize(1);
  tft.print("Established Connection");
  tft.drawLine(myWidth - 50, myHeight * 4 / 12, myWidth - 35, myHeight * 5 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 49, myHeight * 4 / 12, myWidth - 34, myHeight * 5 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 48, myHeight * 4 / 12, myWidth - 33, myHeight * 5 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 47, myHeight * 4 / 12, myWidth - 32, myHeight * 5 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 35, myHeight * 5 / 12 - 10, myWidth * 15 / 16 + 10, myHeight * 3 / 12, GREEN);
  tft.drawLine(myWidth - 34, myHeight * 5 / 12 - 10, myWidth * 15 / 16 + 9, myHeight * 3 / 12, GREEN);
  tft.drawLine(myWidth - 33, myHeight * 5 / 12 - 10, myWidth * 15 / 16 + 8, myHeight * 3 / 12, GREEN);
  tft.drawLine(myWidth - 32, myHeight * 5 / 12 - 10, myWidth * 15 / 16 + 7, myHeight * 3 / 12, GREEN);
void passedbar2() {
  int senpak;
  tft.setTextSize(1);
  tft.print("Packet Sent");
  // draws lines
  tft.fillRect(myWidth - 50, myHeight * 6 / 12, 30, 15, WHITE);
  tft.drawLine(myWidth - 50, myHeight * 6 / 12, myWidth - 35, myHeight * 7 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 49, myHeight * 6 / 12, myWidth - 34, myHeight * 7 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 48, myHeight * 6 / 12, myWidth - 33, myHeight * 7 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 47, myHeight * 6 / 12, myWidth - 32, myHeight * 7 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 35, myHeight * 7 / 12 - 10, myWidth * 15 / 16 + 10, myHeight * 5 / 12, GREEN);
  tft.drawLine(myWidth - 34, myHeight * 7 / 12 - 10, myWidth * 15 / 16 + 9, myHeight * 5 / 12, GREEN);
  tft.drawLine(myWidth - 33, myHeight * 7 / 12 - 10, myWidth * 15 / 16 + 8, myHeight * 5 / 12, GREEN);
  tft.drawLine(myWidth - 32, myHeight * 7 / 12 - 10, myWidth * 15 / 16 + 7, myHeight * 5 / 12, GREEN);
void passedbar3() {
  int ovrpak;
  tft.setTextSize(1);
  tft.print("Protocol Bypassed");
  // draws lines
  tft.fillRect(myWidth - 50, myHeight * 8 / 12, 30, 15, WHITE);
  tft.drawLine(myWidth - 50, myHeight * 8 / 12, myWidth - 35, myHeight * 9 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 49, myHeight * 8 / 12, myWidth - 34, myHeight * 9 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 48, myHeight * 8 / 12, myWidth - 33, myHeight * 9 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 47, myHeight * 8 / 12, myWidth - 32, myHeight * 9 / 12 - 10, GREEN);
  tft.drawLine(myWidth - 35, myHeight * 9 / 12 - 10, myWidth * 15 / 16 + 10, myHeight * 7 / 12, GREEN);
  tft.drawLine(myWidth - 34, myHeight * 9 / 12 - 10, myWidth * 15 / 16 + 9, myHeight * 7 / 12, GREEN);
  tft.drawLine(myWidth - 33, myHeight * 9 / 12 - 10, myWidth * 15 / 16 + 8, myHeight * 7 / 12, GREEN);
  tft.drawLine(myWidth - 32, myHeight * 9 / 12 - 10, myWidth * 15 / 16 + 7, myHeight * 7 / 12, GREEN);
void softwareReset(uint8_t prescaller) {
  wdt_enable(prescaller);
  while (1) {}
mikeysklar
Re: Security Access tuner replica from alien isolation
Post by mikeysklar »
Awesome build. Thank you for sharing.
One suggestion. With your shots of the full unit on thingiverse have the display on. Most of them have the display off.
knoxvilles_Joker
I try. It is as accurate as I can make it within time constraintes...
Return to “Arduino”
