Does anyone know where I can find the the above code?
The red LED is blinking and the neopixel is cycling through different colors. The serial monitor is printing a timestamp, RSSI info and packet data. The bluetooth is not connected to anything.
I thought it might be one of the UART examples, but the ones that I checked does not have LED or neopixel control.
Timestamp Addr Rssi Data
001289806 7A:09:F5:E1:24:7C -65 02-01-1A-02-0A-04-0A-FF-4C-00-10-05-03-18-74-6C-35
001290080 7A:09:F5:E1:24:7C -64 02-01-1A-02-0A-04-0A-FF-4C-00-10-05-03-18-74-6C-35
001290899 7A:09:F5:E1:24:7C -69 02-01-1A-02-0A-04-0A-FF-4C-00-10-05-03-18-74-6C-35
001291171 7A:09:F5:E1:24:7C -68 02-01-1A-02-0A-04-0A-FF-4C-00-10-05-03-18-74-6C-35
Mark
Arduino code that is shipped on Itsibitsy nRF52840
- marklb
- Franklin97355
- adafruit2
Re: Arduino code that is shipped on Itsibitsy nRF52840
This is an example for our nRF52 based Bluefruit LE modules
Pick one up today in the adafruit shop!
products from Adafruit!
MIT license, check LICENSE for more information
All text above, and the splash screen below must be included in
any redistribution
#include <bluefruit.h>
#include <Adafruit_DotStar.h>
#define DATAPIN 8
#define CLOCKPIN 6
Adafruit_DotStar strip(1, DATAPIN, CLOCKPIN, DOTSTAR_BRG);
void setup()
Serial.begin(115200);
strip.begin();
strip.setPixelColor(0, 0, 50, 0);
strip.setBrightness(20);
strip.show(); // Initialize all pixels to 'off'
Serial.println("Bluefruit52 Central Scan Example");
Serial.println("--------------------------------\n");
// Initialize Bluefruit with maximum connections as Peripheral = 0, Central = 1
// SRAM usage required by SoftDevice will increase dramatically with number of connections
Bluefruit.begin(0, 1);
// Set max power. Accepted values are: -40, -30, -20, -16, -12, -8, -4, 0, 4
Bluefruit.setTxPower(4);
Bluefruit.setName("Bluefruit52");
// Start Central Scan
Bluefruit.setConnLedInterval(250);
Bluefruit.Scanner.setRxCallback(scan_callback);
Bluefruit.Scanner.start(0);
Serial.println("Scanning ...");
void scan_callback(ble_gap_evt_adv_report_t* report)
Serial.println("Timestamp Addr Rssi Data");
Serial.printf("%09d ", millis());
// MAC is in little endian --> print reverse
Serial.printBufferReverse(report->peer_addr.addr, 6, ':');
Serial.print(" ");
Serial.print(report->rssi);
Serial.print(" ");
Serial.printBuffer(report->data.p_data, report->data.len, '-');
Serial.println();
// Check if advertising contain BleUart service
if ( Bluefruit.Scanner.checkReportForUuid(report, BLEUART_UUID_SERVICE) )
Serial.println(" BLE UART service detected");
Serial.println();
// For Softdevice v6: after received a report, scanner will be paused
// We need to call Scanner resume() to continue scanning
Bluefruit.Scanner.resume();
uint8_t i=0;
void loop()
strip.setPixelColor(0, Wheel(i++));
strip.show();
delay(10);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
