airlift example code
davidsi
Post by davidsi »
is there any sample code for the airlift co processor in C, not python? I am having a hard time understanding how to program the co processor.
jerryn
Re: airlift example code
Post by jerryn »
I'm not sure what you are trying to do or what boards you are using, but there are guides to using an AirLift with the Arduino IDE here
https://learn.adafruit.com/adafruit-air ... ng/arduino
and for upgrading the Firmware on an Airlift here:
https://learn.adafruit.com/upgrading-es ... e/overview
and
The NINA Firmware is here if you want to modify it.
https://github.com/adafruit/nina-fw
I hope that helps.
Note: I do not represent Adafruit. Just trying to help.
davidsi
Post by davidsi »
thanks for your answer but it does not help. I have the Adafruit 4201 Airlift – ESP32 WiFi Co-Processor Breakout Board, not a feather board. Which seemingly I can not attach to the Arduino IDE
jerryn
Post by jerryn »
davidsi
Post by davidsi »
so if I read that correctly, I don't need to program the airlift at all, just communicate with it? That would be awesome
jerryn
Post by jerryn »
Yes, you may need to update the Airlift firmware as described in an earlier link, but first you should be just able to use it as is to test it out.
davidsi
Post by davidsi »
is there an LED that is supposed to light up if it has power across 5v/Gnd?
jerryn
Post by jerryn »
Looking at the schematic on the guide for the Airlift Breakout, I do not see an LEB on the input power.
https://learn.adafruit.com/adafruit-air ... /downloads
davidsi
Post by davidsi »
ooh, thank you
Return to “Internet of Things: Adafruit IO and Wippersnapper”
