Playing wav files with circuit playground express without SD card
efeigenbaum
Post by efeigenbaum »
Is there a way to play a wav file on a Circuit Playground Express without an SD card using Arduino coding? I saw a tutorial for python but not for Arduino. I tried the CircuitPlayground.play_file command but it failed. Can you offer some advice? Thanks.
Franklin97355
Re: Playing wav files with circuit playground express without SD card
Post by Franklin97355 »
Can you post the link to the tutorial you saw and give us an idea of what you ant to play?
efeigenbaum
Sure. Here is the link:
https://learn.adafruit.com/make-it-talk?view=all
I want to make it say the temperature out loud so I need it to say numbers as well as multiples of ten (thirty, forty, etc)
Thanks.
efeigenbaum
So I figured out how to convert a wav file to HEX and to DEC format. What I'd like to know is - is there a comparable command in Arduino language that can play a wave file like there is with Python (.play_file)?
Return to “For Educators”
