Can't get inputs on QTPY 2040
Adafruit's tiny microcontroller platform. Please tell us which board you are using.
ChuckDrexel
Post by ChuckDrexel »
This has got to be and absolute beginners mistake, but I've done this 100 times on other processors of all types. I can't get a simple pushbutton input to work, and I'm at a loss to know what is happening here. Complies, loads and runs, but only shows Inputs equal to 1, regardless of grounding the pins. Got to be something obvious, but I'm not getting it. Help!!! Thanks!
  int In0=0;
  int In1=1;
  int In2=2;
  int In3=3;
  int inval;
void setup()
  // put your setup code here, to run once:
  pinMode(0,INPUT_PULLUP);
  pinMode(1,INPUT_PULLUP);
  pinMode(2,INPUT_PULLUP);
  pinMode(3,INPUT_PULLUP);
  delay(5000);
  Serial.println("start");
  // put your main code here, to run repeatedly:
  inval=digitalRead(In0);
  Serial.print("IN0=");
  Serial.println(inval);
  inval=digitalRead(In1);
  Serial.print("IN1=");
  inval=digitalRead(In2);
  Serial.print("IN2=");
  inval=digitalRead(In3);
  Serial.print("IN3=");
  delay(3000);
Last edited by adafruit_support_carter on Fri Apr 28, 2023 2:02 pm, edited 1 time in total.
Reason: added [code] tags
Re: Can't get inputs on QTPY 2040
None of those pins (0-3) are brought out for the QT PY RP2040. See here for pinout info:
https://learn.adafruit.com/adafruit-qt-py-2040/pinouts
ChuckDrexel
OH!!! That was one thing I ASSUMED - A0 = GPIO0 (NOT!) ALWAYS a bad idea to assume. I accidentally discovered that if I called the pins A0 - A3 it worked fine! Another lesson learned the hard way! Thanks!
Return to “Trinket ATTiny, Trinket M0”
