Issues connecting Pico W to WipperSnapper
spovlot
Post by spovlot »
I am trying to add a new device with WipperSnapper. Followed the "New Device" instructions for adding WipperSnapper to my Raspberry Pi Pico W. I loaded the latest UF2 (wippersnapper.rpi_pico_w.1.0.0-beta.61.uf2) and updated the secrets.json with my credentials. I have unplugged and reattached the board to reset it.
The Pico W continues to disconnect the USB drive. I am seeing the LED flash 3 times, then 4 times for a few cycles and then solid until it disconnects.
Can you provide additional troubleshooting steps?
brubell
Learn User Page
Re: Issues connecting Pico W to WipperSnapper
Post by brubell »
Sure!
Prior to the disconnect, could you:
1) When the LED is solid - copy and paste the output of the boot_out.txt file on the WIPPER drive here.
2) When it is still connecting, plug your Pico W into USB and visit https://www.serialterminal.com. Please paste the debug output from serial terminal.com here so I can analyze it.
spovlot
Post by spovlot »
wipper_boot_out.txt:
Adafruit.io WipperSnapper
Firmware Version: 1.0.0-beta.61
Board ID: rpi-pico-w
MAC Address: 28:CD:C1:08:ED:BA
From https://www.serialterminal.com.
Attempting to connect to WiFi...
ERROR [WDT RESET]: ERROR: Unable to connect to WiFi, rebooting soon...
I double checked my wifi credentials in secrets.json.
brubell
Learn User Page
Post by brubell »
Is the WiFi network you're connecting to a 2.4GHZ network?
spovlot
Post by spovlot »
My router is dual band and allows both 2.4 and 5 GHz. The router even shows it as a "connected device".
brubell
Learn User Page
Post by brubell »
Could you possibly to tether it to your Phone's wireless hotspot, or try another network?
spovlot
Post by spovlot »
FYI. I loaded CircuitPython 8.0.5 on the same Pico W. And it connects fine.
Adafruit CircuitPython 8.0.5 on 2023-03-31; Raspberry Pi Pico W with rp2040
soft reboot
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
Connecting to WiFi
Connected to WiFi
My MAC addr: ['0x28', '0xcd', '0xc1', '0x8', '0xed', '0xba']
My IP address is 10.0.0.151
Ping google.com: 32.999985 ms
spovlot
Post by spovlot »
I tried my mobile hotspot and it worked. But I still don't see the device under https://io.adafruit.com/spovlot/devices
Attempting to connect to Adafruit IO...
Registering hardware with WipperSnapper...
Registering hardware with IO...
Encoding registration request...Encoding registration msg...Published!
Polling for registration message response...2
GOT Registration Response Message:
Hardware Response Msg:
	GPIO Pins: 31
	Analog Pins: 4
	Reference voltage: 3.30v
Completed registration process, configuration next!
Polling for message containing hardware configuration...
cbSignalTopic: New Msg on Signal Topic
2 bytes.
decodeSignalMsg
cbSignalMsg
Sub-messages found: 1
Signal Msg Tag: Pin Configuration
Initial Pin Configuration Complete!
Publishing to pin config complete...
Hardware configured successfully!
Registration and configuration complete!
Running application...
PING!
PING!
PING!
spovlot
Post by spovlot »
Well, I was on io.adafruit.com when the Pico W restarted and I got a "Register Device" dialog. Seems OK now.
Hopefully I can switch back to my regular wifi.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
