TCS3472 not found on ATTiny85
gtmans
Post by gtmans »
I am trying to transfer this project with TCS3472 color sensor from Arduino Nano to ATTiny85. At first I encountered some problems compiling the project because the "Adafruit_TCS34725.h" is using the arduino wire library, but finally succeeded compiling it successfull by using ATTinycore with options Board: ATTiny/25/45/85(no bootloader) and Programmer: Arduino as ISP. The next problem is that the TCS3472 somehow does not initialise. I use i2c connections that I used in other projects: SCL pin4 and SDA pin0. Tried using TinyWireM.h and wire.h which both compiles OK. Any suggestions? (beginner)
I tried this:
  • wrote a i2c scanner that displays the found address binairy on the led strip but it finds nothing
  • checked the ATTiny is running at 16MHz : Yes
  • Wire.setClock() to set the I2C clock speed to 100kHz and 10kHz, which should be compatible with the ATTiny85.
  • two pullups of 10k to sda and scl
  • 3.3v and 5v
  • compiled succesfully with wire.h or TinyWireM.h
picture and source at https://github.com/gtmans/chameleon/
barshatriplee
Re: TCS3472 not found on ATTiny85
Post by barshatriplee »
Somebody reported the same problem here 2 years ago: https://forum.arduino.cc/t/connection-o ... r/644221/2
Looks like, you cannot use the wire.h library for ATTiny85. Gotta use ATTinyCore.
https://github.com/SpenceKonde/ATTinyCore
gtmans
Post by gtmans »
Yes I read that post and I am using ATTinycore which supports Wire.h thx.
gtmans
Post by gtmans »
// using  ATTinycore (which supports Wire.h)
// Board: ATTiny/25/45/85(no bootloader)
// Programmer: Arduino as ISP
// ATTiny85 running at 16MHz(PLL) and burned bootloader
#define  Tiny         1           // if defined compile for ATTiny85 io. Arduino
#define  Use_TinyWire 1           // if defined uses TiniWireM.h io. Wire.h
#ifdef   Use_TinyWire
  #include <TinyWireM.h>          // I2C Master lib for ATTinys which use USI
//#include <USI_TWI_Master.h>
#else
  #include <Wire.h>
#endif
#ifdef   Tiny
  #include <avr/power.h>          // Required for 16 MHz Adafruit Trinket
  #define LED_PIN    3            // PB3 pin to which the NeoPixels are attached
#else
  #define LED_PIN    6            // pin to which the NeoPixels are attached
#endif
#define   LED_COUNT  8            // number of pixels attached to NEO pixelstrip
#include "Adafruit_TCS34725.h"
Adafruit_NeoPixel strip (LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_4X);//https://learn.adafruit.com/adafruit-color-sensors/library-reference
int minr,ming,minb,maxr,maxg,maxb;
int myred,mygre,myblu;
  #ifndef  Tiny
    Serial.begin              (115200);
    while                     (!Serial);
    Serial.println            ("Color View Test!");
  #endif
  strip.begin();              // INITIALIZE NeoPixel strip object (REQUIRED)
  strip.show();               // Turn OFF all pixels ASAP
  strip.setBrightness(5);     // Set BRIGHTNESS to about 1/5 (max = 255)
  #if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
    clock_prescale_set(clock_div_1);
//  USI_TWI_Master::init();
//  TinyWireM::USI_TWI_Master twi;
    #ifndef   Use_TinyWire
//    Wire.setClock(100000);  // set I2C clock speed to 100kHz
      Wire.setClock(10000);   // set I2C clock speed to 100kHz
    #endif                    // TinyWireM.setClock() doesnot exist
    setcolor(0,255,0);        // green: processor is running at 16mhz
  #else
    setcolor(255,0,0);        // red:   processor is not running at 16mhz or not ATTiny
  #endif
  delay(1000);
  displayAddresses();         // scan i2c bus for devices and diplay found address binairy on 8 pixel ledstrip
  if (tcs.begin()) {
  #ifndef  Tiny
    Serial.println            ("Found sensor");
  #else
    setcolor                  (0,0,255);//blue: show blue leds found sensor
  #endif
  } else {
  #ifndef  Tiny
    Serial.println            ("No TCS34725 found ... check your connections");
  #else
    setcolor                  (255,0,255);//violet: no sensor found
  #endif
  while (1);                  // halt!
  setcolor(0,255,0);          //green: show everything is OK
  delay                       (1000);
  minr=255;
  ming=minr;
  minb=minr;
  float red, green, blue;
  delay(60);  // takes 50ms to read
  tcs.getRGB     (&red, &green, &blue);
  if (red>maxr)  {maxr=red;}
  if (red<minr)  {minr=red;}
  if (green>maxg){maxg=green;}
  if (green<ming){ming=green;}
  if (blue>maxb) {maxb=blue;}
  if (blue<minb) {minb=blue;}
  myred=map(int(red),  minr,maxr,0,255);
  mygre=map(int(green),ming,maxg,0,255);
  myblu=map(int(blue), minb,maxb,0,255);
#ifndef  Tiny
  Serial.print("R:");   Serial.print(String(int(red))  +"("+String(minr)+"-"+String(maxr)+")");
  Serial.print("\tG:"); Serial.print(String(int(green))+"("+String(ming)+"-"+String(maxg)+")");
  Serial.print("\tB:"); Serial.print(String(int(blue)) +"("+String(minb)+"-"+String(maxb)+")");
  Serial.print("\t");
  Serial.print((int)red, HEX); Serial.print((int)green, HEX); Serial.print((int)blue, HEX);
  Serial.print("\t");
  Serial.print(String(myred)+"/"+String(mygre)+"/"+String(myblu));
  Serial.print("\n");
#endif
  setcolor  (myred,mygre,myblu);
  delay     (100);
void setcolor(int r,int g,int b){
  strip.clear ();
  for         (int n=0;n<LED_COUNT;n++){
    strip.setPixelColor(n, strip.Color(r,g,b));
    strip.show();
    delay   (250);
void displayAddresses() {
  int nDevices = 0;
  #ifndef  Tiny
    Serial.println("Scanning...");
  #endif
  #ifdef   Use_TinyWire
  //const uint32_t TWI_SPEED = 100000UL; // desired clock speed
  //TinyWireM.begin(TWI_SPEED); // set I2C clock frequency to 100 kHz does not work
    TinyWireM.begin();
  #else
    Wire.begin();
  #endif
  for (byte address = 1; address < 127; ++address) {
    byte saveA=address;
    byte binaryAddress[8]="00000000";
    byte index = 0;
    // Converteer het I2C-adres naar binaire notatie
    while (saveA > 0) {
      binaryAddress[index++] = saveA % 2;
      saveA /= 2;
    strip.clear ();
    // Schrijf het binaire adres naar de ledstrip
    for (int i = 0; i < 8; i++) {
      if (binaryAddress[i] == 1) {
        strip.setPixelColor(i, 255);
      } else {
        strip.setPixelColor(i, 0);
    strip.show();
    #ifndef  Tiny
      Serial.println(address);
    #endif
      TinyWireM.beginTransmission(address);
      byte error = TinyWireM.endTransmission();
    #else
      Wire.beginTransmission(address);
      byte error = Wire.endTransmission();
    #endif
    if (error == 0) {
      #ifndef  Tiny
        Serial.print("I2C device found at address 0x");
        if (address < 16) {
          Serial.print("0");
        Serial.print  (address, HEX);
        Serial.print  ("HEX ");
        Serial.print  (address, BIN);
        Serial.println("BIN");
      #endif
      ++nDevices;
      delay(5000);
    } else if (error == 4) {
      #ifndef  Tiny
        Serial.print("Unknown error at address 0x");
        if (address < 16) {
          Serial.print("0");
        Serial.println(address, HEX);
      #else
        setcolor(255,255,0);//REDGREEN
        delay   (5000);
      #endif
      delay(50);
    if (nDevices == 0) {
    #ifndef  Tiny
      Serial.println("No I2C devices found\n");
    #else
      setcolor(0,255,255);//BLUEGREEN
      delay   (5000);
    #endif
gtmans
Post by gtmans »
I could not get the TCS3472 color sensor to work with ATTiny85. So I switched to Seeeduino Xiao and it works like a charm. This post can be closed, thanks for your help. More at https://github.com/gtmans/chameleon
Return to “Microcontrollers”
