eror code on pro trinket upload
Plasticsrepent
Post by Plasticsrepent »
I just completed a project using a pro trinket 5 V 16 MHz FTDI, and I ran into something I've never seen before.
The code I wrote compiled without a problem, then I pushed the reset button and got the normal, pulsing red LED.
I clicked upload and everything went as expected and at the end it said, "upload complete".
one second later I got this error code. avrdude: stk500_disable(): unknown response=0x30
but the code runs as intended, and the project works perfectly. What does that code mean, and is there something I should be concerned about because the project works?
mikeysklar
Re: eror code on pro trinket upload
Post by mikeysklar »
What else is connected to the Trinket Pro? Do you see the same error during upload if there are no other accessories?
Can you enable verbose upload output (File --> Preferences)? There might be some more details and you can copy the error message and paste in a code tag here.
