Hello all,
I am trying to build the Tamaguino project found here: https://alojzjakob.github.io/Tamaguino/
As the instructions show you have to use older versions of the libraries to get the sketch size to be small enough. I have gone ahead and done so, however, the sketch is still too big. I am using an Arduino Pro Micro Atmega32U4 5V 16MHz with a bootloader.
Are there any other small form factor boards I can try or does anyone know how to get the sketch smaller?
Thank you!
Sketch Size Too Large
- dastels
Re: Sketch Size Too Large
The code looks to be fairly 8-bit specific so it will take some work to get it working on a bigger MCU like a SAMD21 on one of the "M0" boards.
It will just barely fit onto a ATmega328 so you could try a Metro Mini 328 https://www.adafruit.com/product/2590 or Feather 328P https://www.adafruit.com/product/3458. I compiled it for the latter and it took 97% of the flash.
- paintlax
Any work needed on the code to make it work with the feather?
- dastels
The Feather 328, no. It's essentially an UNO in feather format.
