NTSC display questions
doctorwho8
Post by doctorwho8 »
Hello!
I bought from Micro Center a while back this guy, [url]https://www.adafruit.com/product/946/url] and I've also managed to work out how to export composite video from a Pi Zero, it involved installing a header on the open points marked TV. Now I have it displaying text on the rig. Of course the big question involved is in shrinking the text so that it is properly shown.
I enabled things here:
# uncomment for composite
sdtv_mode=1
I then set things here:
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
overscan_left=42
overscan_right=42
overscan_top=84
overscan_bottom=84
# uncomment to force a console size. By default it will be display's size minus
# overscan.
framebuffer_width=320
framebuffer_height=240
It seems that no matter how much I increase the top and bottom numbers, I can't shrink the screen to match the size of display. As always I am deferring to the people at Adafruit who possibly tried out the display when it was first available.
adafruit_support_mike
Re: NTSC display questions
The display's resolution is 480 x 272. Try using that instead of the 320 x 240 listed above.
doctorwho8
adafruit_support_mike wrote: Sat May 06, 2023 3:41 am The display's resolution is 480 x 272. Try using that instead of the 320 x 240 listed above.
Hello!
That looks better. Now I need to work on the overscan settings. What would be good settings for the top and bottom entries?
It varies from one display to another. You'll have to work it out by trial and error.
surganova
Post by surganova »
Hi, item 913 (https://www.adafruit.com/product/913).
Question: if there is no signal, what is on the screen? "Snow", or blue screen like on most of the displays? Thanks.
Return to “Adafruit Raspberry Pi® accessories”
