Has anyone successfully connected an ESP32 S2 Metro M4 to an Android Personal Hotspot for use with I / O feeds?
NEO PIXEL turns straight yellow.
Android Hotspot for ESP32 S2 Metro?
- esus
Re: Android Hotspot for ESP32 S2 Metro?
Update: I erased the uf2.bin file and the whole flash drive, reinstalled as per instructions and got a slightly different result.
When I reset the device after dragging nd dropping wipper and secrets file I got 3 yellow NEO ixel pulses and then a flashing green light about once every 5 seconds.
However it hasn't connected to the hotspot and it hasn't showed up in I/O feeds.
- brubell
- Learn User Page
Hi, I am trying to help figure this out so bear with me.
Are you trying to use WipperSnapper on the ESP32-S2 Metro?
Are you trying to connect the ESP32-S2 Metro, running WipperSnapper, to your mobile hotspot?
With the ESP32-S2 Metro connected to your computer via USB, could you open the WIPPER drive on your computer. On that drive, the secrets.json file should contain your WiFi network credentials and Adafruit IO credentials. Please verify that they are correct.
