Hi there
I am after little bit of help
I have a grand central and a raspberry pi 3 with Arduino installed but I can't seem to get he Grand central visible in the serial ports, I have added the Adafruit SAMD in the board manager but it still not visible
The raspberry pi works fine with the other boards that I have ie a UNO, MKR100 and Vidor400, pico
and the grand central works fine on on my Mac Laptops
The grand central has been update to latest bootloader version: v3.15.0
I am running a Raspberry Pi OS 32bit OS but have tried a 64bit as well but it not helping
It feel like I am missing a driver somewhere but can't find it any where
Any help would be greatly appreciated
Cheers
James
Raspberry pi and Grand Central
- adafruit_support_carter
Re: Raspberry pi and Grand Central
Try checking dmesg to see what, if anything, is happening when the Grand Central is plugged in.
Start with the Grand Central unplugged.
Then run this on the Pi in a command line terminal window:
Then plug in the Grand Central and watch for any new messages to show up.
dmesg -w
- jamesob
Thanks for getting back to me,
In the Demesg it report issue of Under-voltage detected! I tried a few different power supply to the raspberry pi and the board but nothing really changed, I've now order a official raspberry pi power adaptor just to rule that out
Is there a grand central very power hungry compared to other boards, like a UNO or MKR 4000 ?
Cheers
James
Cheers
James
Easy enough to test with the Pi. If you watch dmesg output when plugging in those boards, do they generate under-voltage warnings?Is there a grand central very power hungry compared to other boards, like a UNO or MKR 4000 ?
- jamesob
I've got a powered 2.5A power supply, but unfortunately it still not working,
when I run 'dmesg -w' and plug the board in via usb no extra message are shown
On my MacBook 2012 (with usb 3) the board works every time, on my MacBook m1 (with usb-c ) it can be be a little hit and miss but neither works if I use a hub (however it used to). The raspberry pi the board powers up but isn't visible in the serial ports
Could this be a firmware issue or could of my board developed a fault
Cheers
James
Cheers
James
How are you connecting to the Pi? Do you have a keyboard/monitor attached? Or are you sshing in?
- jamesob
The other boards don't report a under voltage issue also when you plug it in you can see but you do get to see useful I info like the board make serial port etc
If you plug in the grand central board in with out using a external power supply (on the board not the raspberry pi) then in the dmesg output it flags under voltage issue but no more info
If you plug it in with a power supply then you get no info at all
What I am trying to working out is it worth getting another grand central or will this not work with a raspberry pi either
Any Help would be greatly appreciated
Cheers
James
Cheers
James
It's still unclear how you are interacting with the Pi. SSH? something else?
Try double pressing the reset button on the GC to get into bootloader mode. That should generate messages.
- jamesob
Sorry forgot to add, I am using a usb mouse/keyboard and monitor, but have tried disconnecting everything and ssh in instead but not change
I've just tried pressing he reboot button and nothing appears in the dmesg output, it would noting that the keyboard and mouse show up dmesg when I start up
Not sure what the issue is.
The USB on the Pi seems fine since keyboard and mouse are working.
The Grand Central is fine since it works on a Mac.
I just test plugging a Grand Central into a Pi with nothing but a USB cable (no extra power) and got this in dmesg:
And after double pressing reset, this:[21702.044389] usb 1-1.1.2: new full-speed USB device number 8 using dwc_otg
[21702.195578] usb 1-1.1.2: New USB device found, idVendor=239a, idProduct=8031, bcdDevice= 1.00
[21702.195614] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[21702.195632] usb 1-1.1.2: Product: Grand Central M4
[21702.195646] usb 1-1.1.2: Manufacturer: Adafruit
[21702.195659] usb 1-1.1.2: SerialNumber: 2C856B735335353334202020FF184B20
[21702.198825] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
Are any of the LEDs on the Grand Central coming on when double press reset?[21755.508287] usb 1-1.1.2: USB disconnect, device number 8
[21756.314236] usb 1-1.1.2: new full-speed USB device number 9 using dwc_otg
[21756.448704] usb 1-1.1.2: New USB device found, idVendor=239a, idProduct=0031, bcdDevice=42.01
[21756.448740] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[21756.448757] usb 1-1.1.2: Product: Grand Central M4 Express
[21756.448771] usb 1-1.1.2: Manufacturer: Adafruit Industries
[21756.448785] usb 1-1.1.2: SerialNumber: 2C856B735335353334202020FF184B20
[21756.454038] cdc_acm 1-1.1.2:1.0: ttyACM0: USB ACM device
[21756.455960] usb-storage 1-1.1.2:1.2: USB Mass Storage device detected
[21756.456601] scsi host0: usb-storage 1-1.1.2:1.2
[21756.461047] hid-generic 0003:239A:0031.0003: hiddev96,hidraw1: USB HID v1.00 Device [Adafruit Industries Grand Central M4 Express] on usb-3f980000.usb-1.1.2/input3
[21757.515275] scsi 0:0:0:0: Direct-Access Grand Ce ntral M4 Express 1.00 PQ: 0 ANSI: 2
[21757.515927] sd 0:0:0:0: Attached scsi generic sg0 type 0
[21757.516876] sd 0:0:0:0: [sda] 8000 512-byte logical blocks: (4.10 MB/3.91 MiB)
[21757.517366] sd 0:0:0:0: [sda] Write Protect is off
[21757.517389] sd 0:0:0:0: [sda] Mode Sense: 0f 00 00 00
[21757.517868] sd 0:0:0:0: [sda] No Caching mode page found
[21757.517888] sd 0:0:0:0: [sda] Assuming drive cache: write through
[21757.538899] sda:
[21757.539458] sd 0:0:0:0: [sda] Attached SCSI removable disk
- jamesob
Thankyou so much for looking into this and going to trouble testing on you own set up
when I double press while connected to the pi I can alter between red on the Neo pixel and and just the green/yellow on the smaller leds, but matter what I try I can't get the Neo pixel to go green
on the Mac's I can switch between green and red on the Neo pixel
Cheers
James
Cheers
James
Getting red on the NeoPixel after double pressing reset is an indication of a USB connection issue.
How many different USB cables have you tried?
