Problem consistently communicating with Adafruit.io data dashboard
femur
Re: Problem consistently communicating with Adafruit.io data dashboard
Post by femur »
Ah ha! OK! Thank you.
femur
Post by femur »
I'm still getting an error on the exception. I tried both "MMQTTException" and "MQTTException".
Are these exceptions built into the library?
Screen Shot 2023-04-30 at 2.00.50 PM.png (23.41 KiB) Viewed 370 times
Screen Shot 2023-04-26 at 3.36.28 PM.png (18.78 KiB) Viewed 370 times
mikeysklar
Post by mikeysklar »
These are from the library, but we should be able to catch and continue with the try/except setup.
What does your code look like for catching both?
femur
Post by femur »
Here's the code I've been using:
https://gist.github.com/extrasleepy/875 ... 7d4aeec01f
check out lines 127 to 132 to see the "try...except" problem.
I've also included an image of my libraries.
Thank you!
Screen Shot 2023-05-02 at 1.16.10 PM.png (140.3 KiB) Viewed 358 times
mikeysklar
Modify your try/except to handle both errors. Modify line 130 of your code from this:
        except MMQTTException as mqttissue:
to this:
        except (MMQTTException, MQTTException) as mqttissue:
femur
Post by femur »
OK. I'll give this a try tomorrow.
femur
Post by femur »
I'm still getting the same error unfortunatetly:
Screen Shot 2023-05-10 at 8.34.45 AM.png (15.04 KiB) Viewed 318 times
mikeysklar
There is an open issue on this:
https://github.com/adafruit/Adafruit_Ci ... issues/163
Since the person who started it was not able to continue testing you should jump in with your setup:
* Hardware setup
* CircuitPython version
* Library versions
* A short description of the time duration before the problem appears
* The code you are running
* The error message should be enough to start the discussion
The last suggestion was to try this:
from adafruit_minimqtt.adafruit_minimqtt import MMQTTException
femur
Post by femur »
Ok. I'll do that soon. Thank you again.
Return to “Internet of Things: Adafruit IO and Wippersnapper”
