I bought this LED Matrix panel https://www.adafruit.com/product/2026 (Order No: 3006067-3551398010), and it is not working as it should. There are a few rows (from top: rows 6,7,14 and 21) where the Leds light up when they shouldn´t. When anything on the same column is lit those rows also light up.( see images ) I´ve tried with different example codes, different controllers: Teensy with a SmartLed shield and an Arduino Mega and always the same glitch.
Is there anything I can do to fix the panel? Like fixing the soldering in an oven like people have done with graphics cards. Any suggestions?
How to Fix LED Matrix panel?
- adafruit_support_carter
Re: How to Fix LED Matrix panel?
How are you making the connection between the matrix panel and the controller boards?
- Gaurinn
Teensy 4.0 is connected using a SmartLED shield v5, and the ArduinoMega connected using wires.
Direct wiring with jumper wires is very problematic and not supported:
https://learn.adafruit.com/32x16-32x32- ... mper-wires
The SmartLED shield should generally be OK though. Are you following this for setup?
https://docs.pixelmatix.com/SmartMatrix/shield-t4.html
Are you running one of the examples from the library?
https://github.com/pixelmatix/SmartMatr ... r/examples
- Gaurinn
To answer you questions, Yes, Yes and Yes.
Jumper cables are problematic.
Followed the pixelmatix instructions.
Running the SmartMatrix examples.
Please try posting in the pixelmatix forums:
https://community.pixelmatix.com/
Specify exactly which one of their examples you are running in the photo above.
