ItsyBitsy RP2040 vs Feather RP2040 audiomixer | MP3Decoder
JohnBottle
Post by JohnBottle »
Is there any reason why the ItsyBitsy RP2040 would not be as good as the Feather RP2040 regarding mp3 decoding and playback using audiomixer??
I've been trying for hours - using parts of the code found here:
https://learn.adafruit.com/walkmp3rson- ... alkmp3rson
I set the buffer_size=32768 - which finally let the mp3 files play:
mixer = audiomixer.Mixer(voice_count=2, sample_rate=44100, channel_count=1,bits_per_sample=16, samples_signed=True, buffer_size=32768)
But they are so crackly, and always a loud "pop" when first playing.
If I use MP3Decoder on it's own, like this:
a = AudioOut(board.A0)
mymp3 = MP3Decoder(open("sound.mp3", "rb"))
a.play(mymp3)
There is a loud pop on first, play, but it sounds ok.
As soon as I try and use audiomixer, the sound becomes crackly...
ffile1 = MP3Decoder(open("sound.mp3", "rb"))
ffile2 = MP3Decoder(open("sound2.mp3", "rb"))
a.play(mixer)
mixer.voice[0].level = 0.5
mixer.voice[1].level = 0.5
mixer.voice[0].play(ffile1, loop=True)
mixer.voice[1].play(ffile2, loop=True)
Is this a limitation of the ItsyBitsy vs Feather??? Something to do with??
from audiopwmio import PWMAudioOut as AudioOut # For ItsyBitsy
from audioio import AudioOut # For Feather?
For playing mutltiple mp3 files with mixer, and good quality audio, what is best (lowest-cost) adafruit chip with 8mb of Flash like ItsyBitsy. Why does feather only have 2mb?
Thanks for help!
mikeysklar
Re: ItsyBitsy RP2040 vs Feather RP2040 audiomixer | MP3Decoder
Post by mikeysklar »
Are you using the example sound files from the walkmp3rson project? If the encoding were a little off that would create a conflict with the mixer settings.
https://learn.adafruit.com/walkmp3rson- ... le-3126952
The mixer voice is at 0.5 in your code and only 0.15 in the example code. Lowering that might help.
 mixer.voice[0].level = 0.15
The popping should stay surprised as long as the mixer is holding a I2S line. The buffer should be covering up the additional noise caused by activity on the SPI / I2C bus. You can play with the buffersize.
The RP2040 with 8MB is the best chip for this kind of playback today.
Return to “Itsy Bitsy Boards”
