Hi guys,i'm really new to all this world but i'm doing a project for building a theremin device with an esp-32 devkitc v2 and two time of flight sensors VL53L0X .
I need to use one sensor for changing the frequency of the sound and the other one for changing the volume.
My teacher said that i have to use a Midi libray but idk how to use it with the tof sensors.
I've already installed adafruit and the sensors are working,but idk how to implement the sound and also how to use them togheter with only one esp-32.
VL53L0X time of flight and Midi library for a theremin
- Mekscin
- barshatriplee
Re: VL53L0X time of flight and Midi library for a theremin
I think you have use ADafruit MIDI library: https://docs.circuitpython.org/projects ... t/api.html
Since you are using ESP32, you can also use ESP32-BLE-MIDI
https://www.arduinolibraries.info/libra ... 2-ble-midi
- Mekscin
Because i'm using arduino ide,i should try with the second one?barshatriplee wrote: ↑Fri May 19, 2023 11:17 am I think you have use ADafruit MIDI library: https://docs.circuitpython.org/projects ... t/api.html
- barshatriplee
Yes. The first one is for circuitpython.
