Hi.
I'm trying to read some values from a thingspeak channel using the Adafruit Matrix Portal. I tried using the Thinspeak library but I get compilation error beyond my understanding.
Is there a demo or how-to for connecting to thingspeak using the matrix portal ?
Matrix portal and Thingspeak
- tolisn
Re: Matrix portal and Thingspeak
I finally got it to work using the thingspeak lib. I will post the code here once I finish.
- tolisn
The below code works but I have a weird problem. When I power the unit while the Arduino IDE is launced the the unit power correclty and connects to the wifi network and to thingspeak. It also shows The time and the values of the thingspeak channel. When I close the Arduino IDE the unit does not connect to the wifi network. Why is this happening ?
#include <Adafruit_Protomatter.h>
#include <Fonts/FreeSerifItalic9pt7b.h> // Large friendly font
#include <Fonts/TomThumb.h> // small font
#include <WiFi.h>
#include "secrets.h"
#include <NTPClient.h>
#include <WiFiUdp.h>
#include "ThingSpeak.h"
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#if defined(_VARIANT_MATRIXPORTAL_M4_) // MatrixPortal M4
uint8_t rgbPins[] = {7, 8, 9, 10, 11, 12};
uint8_t addrPins[] = {17, 18, 19, 20, 21};
uint8_t clockPin = 14;
uint8_t latchPin = 15;
uint8_t oePin = 16;
#endif
Adafruit_Protomatter matrix(
64, // Width of matrix (or matrices, if tiled horizontally)
6, // Bit depth, 1-6
1, rgbPins, // # of matrix chains, array of 6 RGB pins for each
4, addrPins, // # of address pins (height is inferred), array of pins
clockPin, latchPin, oePin, // Other matrix control pins
true, // No double-buffering here (see "doublebuffer" example)
-2); // Row tiling: two rows in "serpentine" path
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
WiFiClient client;
// Weather station channel details
unsigned long weatherStationChannelNumber = SECRET_CH_ID_WEATHER_STATION;
const char* readAPIKey = SECRET_READ_APIKEY; // your ThingSpeak Read API Key
int statusCode = 0;
int field[8] = {1, 2, 3, 4, 5, 6, 7, 8};
int OutTemp; // Field 1
float pressure; // Field 2
int percentHumid; // Field 3
float BattVolt; // Field 4
float PanelVoltage; // Field 5
float PanelCurrent; // Field 6
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
int timeOffsetHours = 1; // Adjust this offset according to your needs
unsigned long previousTimeMillis = 0;
unsigned long previousTSUpdateMillis = 0;
bool displayTSValues = false;
Serial.begin(115200); // Initialize serial
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo native USB port only
// WiFi.mode(WIFI_STA);
ThingSpeak.begin(client); // Initialize ThingSpeak
// Connect or reconnect to WiFi
if (WiFi.status() != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(SECRET_SSID);
while (WiFi.status() != WL_CONNECTED) {
WiFi.begin(ssid, pass); // Connect to WPA/WPA2 network. Change this line if using an open or WEP network
Serial.print(".");
delay(5000);
Serial.println("\nConnected");
// Initialize matrix...
ProtomatterStatus status = matrix.begin();
Serial.print("Protomatter begin() status: ");
Serial.println((int)status);
if (status != PROTOMATTER_OK) {
// DO NOT CONTINUE if matrix setup encountered an error.
while (1);
matrix.fillScreen(0); // clear the screen
matrix.setCursor(5, 15); // set the cursor position
matrix.setFont(&TomThumb); // Use nice bitmap font
matrix.setTextColor(RED); // set the text color
matrix.show(); // and show it
timeClient.begin(); // Initialize NTPClient
timeClient.setTimeOffset(timeOffsetHours * 10800); // Set the time offset in seconds
unsigned long currentMillis = millis();
// Update time every second
if (currentMillis - previousTimeMillis >= 1000) {
previousTimeMillis = currentMillis;
timeClient.update();
String currentTime = timeClient.getFormattedTime();
// Display current time
matrix.setCursor(0, 15);
matrix.setFont(&FreeSerifItalic9pt7b); // Use large friendly font
matrix.setTextColor(WHITE);
matrix.print(currentTime);
if (displayTSValues) {
// Display ThingSpeak values
matrix.setCursor(0, 38);
matrix.setFont(&TomThumb); // Use small font
matrix.print("Out Temp: " + String(OutTemp) + "°C");
matrix.setCursor(0, 45);
matrix.setTextColor(GREEN);
matrix.print("Humidity: " + String(percentHumid) + " %");
matrix.setCursor(0, 52);
matrix.setTextColor(BLUE);
matrix.print("Pressure: " + String(pressure) );
matrix.setCursor(0, 59);
matrix.setTextColor(CYAN);
matrix.print("Batt. Volt: " + String(BattVolt) + " V");
// Update ThingSpeak values every 15 seconds
if (currentMillis - previousTSUpdateMillis >= 15000) {
previousTSUpdateMillis = currentMillis;
// Read and store all the latest field values
statusCode = ThingSpeak.readMultipleFields(weatherStationChannelNumber, readAPIKey);
if (statusCode == 200) {
// Fetch the stored data
OutTemp = ThingSpeak.getFieldAsInt(field[0]); // Field 1
pressure = ThingSpeak.getFieldAsFloat(field[1]); // Field 2
percentHumid = ThingSpeak.getFieldAsInt(field[2]); // Field 3
BattVolt = ThingSpeak.getFieldAsFloat(field[3]); // Field 4
PanelVoltage = ThingSpeak.getFieldAsFloat(field[4]); // Field 5
PanelCurrent = ThingSpeak.getFieldAsFloat(field[5]); // Field 6
displayTSValues = true;
else {
Serial.println("Problem reading channel. HTTP error code " + String(statusCode));
delay(100);
- tolisn
I got is working, there was a while statement just before the Serial.begin(9600) statement that made the program wait for a com port before executing. Since no comport was available to connect to it never continued to show anything.
