Hi: I have tried the git clone https://github.com/adafruit/Adafruit_Ci ... hon_Bundle twice.
Both time library is full of empty folders, same with helper.
Any ideas? Other gits work fine.
Robert
Circuit Python download
- mikeysklar
Re: Circuit Python download
There are a few more steps for this repo.
https://github.com/adafruit/Adafruit_Ci ... evelopment
After you clone this repository you must run git submodule init and then git submodule update.
For developing individual libraries, please see LIBRARY_DEVELOPMENT.rst.
Updating libraries
To update the libraries run update-submodules.sh. The script will fetch the latest code and update to the newest tag (not main).
To find libraries with commits that haven't been included in a release do:
git submodule foreach "git log --oneline HEAD...origin/main"
Adding a library
Determine the best location within libraries (libraries/drivers/ or libraries/helpers/)for the new library and then run:
git submodule add <git url> libraries/<target directory>
The target directory should omit any CircuitPython specific prefixes such as adafruit-circuitpython to simplify the listing.
- tultalk
Hi: You said "The target directory should omit any CircuitPython specific prefixes such as adafruit-circuitpython to simplify the listing. The libraries are under "D:\Adafruit Circuit Python\Adafruit_CircuitPython_Bundle"
So what to call them?
I have Pythn 3.8 and 3.11UGH!!!
Python 3.8.1 (tags/v3.8.1:1b293b6, Dec 18 2019, 23:11:46) [MSC v.1916 64 bit (AMD64)] on win32
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Python 3.8
Python 3.11.2 (tags/v3.11.2:878ead1, Feb 7 2023, 16:38:35) [MSC v.1934 64 bit (AMD64)] on win32
C:\Users\15172\AppData\Local\Programs\Python\Python311
C:\Users\15172\AppData\Local\python\mu
C:\Users\15172\AppData\Local\Programs\Python\Python311\Lib
What's New in Python 3.11.2 final?
*Release date: 2023-02-07*
And:
D:\lib
D:\Arduino\libraries\lib\circuitpython_nrf24l01
I am lost in the sands of time!!!
Robert
And:
D:\lib
Robert
- mikeysklar
What is it that you are trying to achieve? I might be able to help with more specific commands.
- tultalk
Hi:
Overall project?
Robert
Overall project?
Robert
- mikeysklar
Related to the CircuitPython bundle download from the repo and custom build. Is there a reason you are trying to build your own modules rather than use the pre-compiled MPY’s or uncompiled PY versions?
- tultalk
Hi: trying to build your own modules
I am not trying to build my own modules. Obviously I don't know what I am doing.
Robert
Robert
- mikeysklar
Try downloading the pre-built modules. There is no need to use the github repo for the CircuitPython libraries unless you are customizing a module.
https://circuitpython.org/libraries
- tultalk
That page is very familiar. I will uninstall what I have and start all over.
With regards to 3.8 and 3.11, should I uninstall 3.11 (.8 more recent than .11)
Robert
Robert
- mikeysklar
I would normally read 3.11 as being more recent (eg. 8, 9, 10, 11) but I do not know which library numbering system you are referring to.
- tultalk
I think you are correct.
- tultalk
Attached from file manager. 3.11 must be older since the current downloads are for 3.8
Robert
Robert
- Attachments
- VersionPython.png (3.98 KiB) Viewed 78 times
- tultalk
I will uninstall both and start all over
Robert
Robert
- tultalk
Trying to download CP 8.1. Asks to identify board. Put in UNO and it returns Piunora by Diodes Delight
So I assume this is the correct download.
- tultalk
And that download is for a RPi board. The download site does not allow you to sect an Arduino UNO. Should I select
an Adafruit M7 or M4?
