I recently purchased the HDMI 5” touch display and found it doesn’t seem to display video or even detect a video output. I’ve tried it on both Windows and Mac with multiple HDMI cables. When plugged into power, the green power light lights up as expected and the touch capabilities work just fine. However i noticed the “video - good” light does nothing at all. Any help is appreciated
5” HDMI Backpack display (w/ touch) doesn’t detect video signal
- noahc
- mikeysklar
Re: 5” HDMI Backpack display (w/ touch) doesn’t detect video signal
Have you been setting your resolution manually to 800x480? This screen requires that resolution be used.
- noahc
Initially i thought it would auto-detect the resolution but upon not getting that to work, i went into my display adapter settings (on windows) and manually set it to 800x480 and still got no signal. I’m also concerned because I can’t seem to see any evidence that the backlight is running at all. When initially connected to power, the screen flashes white then seemingly the backlight turns off.
- mikeysklar
Does the same USB cable and port combo work for other devices and the HDMI cable works with other monitors?
Does 640x480 resolution partially work (eg. fills most of the screen width, but not entirely)?
Which version of Windows?
If non of the above helps lets swap it out (return / refund).
- noahc
The micro usb and hdmi cables work fine in other applications. I tried running it on 640x480 but still no signal. This is running on Windows 11.
- mikeysklar
We can do a return or refund on this unit if it was purchased in the last 30 days.
How would you like to proceed?
- noahc
I purchased it through a local Microcenter, would that conflict things with a return/refund? If not I think i’ll do a refund.
- mikeysklar
Good question. I’m not sure how the process works in this case. Please e-mail [email protected] to request a refund and provide them with the Microcenter receipt info. You must provide a link to this forum thread which is your approval.
