I've been trying to make the Adafruit Walkman mp3 player and I believe I have everything wired correctly. Everything is correct as far as I know but it keeps giving me a:
ValueError: No I2C device at address 0x30
I'm told it might be a hardware issue but everything is connects according to the guide:
https://learn.adafruit.com/walkmp3rson- ... on-circuit
Here is the code:
https://learn.adafruit.com/walkmp3rson- ... alkmp3rson
Please help me understand is wrong and what I can do to fix it. Could it be wiring, bad connection, or error in the code.
I2C NeoKey 1x4 error: ValueError: No I2C device at address: 0x30
- Scallopman1739
- dastels
Re: I2C NeoKey 1x4 error: ValueError: No I2C device at address: 0x30
Can you run an i2c scan with only the NeoKey connected? https://learn.adafruit.com/scanning-i2c-addresses
- Scallopman1739
Hi. Thank you for your help. I ran the scan and it's not giving me anything. It's giving me a proper address on my Rotary encoder but not the Neokey
- dastels
OK, it seems DOA. Please email [email protected] with a link to this thread, your order number, and request the replacement of one NeoKey 1x4.
- Scallopman1739
I was able to get a new NeoKey and that part is up and running, but now its giving me a different error.
Is there a value that I need to change?
- dastels
That's an error in the code. Can you post your code.py?
- Scallopman1739
# SPDX-FileCopyrightText: 2022 John Park and Tod Kurt for Adafruit Industries
# Walkmp3rson digital cassette tape player (ok fine it's just SD cards)
import time
import os
import board
import busio
import sdcardio
import storage
import audiomixer
import audiobusio
import audiomp3
from adafruit_neokey.neokey1x4 import NeoKey1x4
from adafruit_seesaw import seesaw, rotaryio
import displayio
import terminalio
from adafruit_display_text import label
from adafruit_st7789 import ST7789
from adafruit_progressbar.progressbar import HorizontalProgressBar
from adafruit_progressbar.verticalprogressbar import VerticalProgressBar
displayio.release_displays()
# SPI for TFT display, and SD Card reader on TFT display
spi = board.SPI()
# display setup
tft_cs = board.D6
tft_dc = board.D9
tft_reset = board.D12
display_bus = displayio.FourWire(spi, command=tft_dc, chip_select=tft_cs, reset=tft_reset)
display = ST7789(display_bus, width=320, height=240, rotation=90)
# SD Card setup
sd_cs = board.D13
sdcard = sdcardio.SDCard(spi, sd_cs)
vfs = storage.VfsFat(sdcard)
storage.mount(vfs, "/sd")
# I2C NeoKey setup
neokey = NeoKey1x4(i2c, addr=0x30)
amber = 0x300800
red = 0x900000
green = 0x009000
neokey.pixels.fill(amber)
keys = [
(neokey, 0, green),
(neokey, 1, red),
(neokey, 2, green),
(neokey, 3, green),
# states for key presses
key_states = [False, False, False, False]
# STEMMA QT Rotary encoder setup
rotary_seesaw = seesaw.Seesaw(i2c, addr=0x36) # default address is 0x36
encoder = rotaryio.IncrementalEncoder(rotary_seesaw)
last_encoder_pos = 0
# file system setup
mp3s = []
for filename in os.listdir('/sd'):
if filename.lower().endswith('.mp3') and not filename.startswith('.'):
mp3s.append("/sd/"+filename)
mp3s.sort() # sort alphanumerically for mixtape order, e.g., "1_King_of_Rock.mp3"
for mp3 in mp3s:
print(mp3)
track_number = 0
mp3_filename = mp3s[track_number]
mp3_bytes = os.stat(mp3_filename)[6] # size in bytes is position 6
mp3_file = open(mp3_filename, "rb")
mp3stream = audiomp3.MP3Decoder(mp3_file)
def tracktext(full_path_name, position):
return full_path_name.split('_')[position].split('.')[0]
# LRC is word_select, BCLK is bit_clock, DIN is data_pin.
# Feather RP2040
audio = audiobusio.I2SOut(bit_clock=board.D24, word_select=board.D25, data=board.A3)
# Feather M4
# audio = audiobusio.I2SOut(bit_clock=board.D1, word_select=board.D10, data=board.D11)
mixer = audiomixer.Mixer(voice_count=1, sample_rate=22050, channel_count=1,
bits_per_sample=16, samples_signed=True, buffer_size=32768)
mixer.voice[0].level = 0.15
# Colors
blue_bright = 0x17afcf
blue_mid = 0x0d6173
blue_dark = 0x041f24
orange_bright = 0xda8c57
orange_mid = 0xa46032
orange_dark = 0x472a16
# display
main_display_group = displayio.Group() # everything goes in main group
display.show(main_display_group) # show main group (clears screen, too)
# background bitmap w OnDiskBitmap
tape_bitmap = displayio.OnDiskBitmap(open("mp3_tape.bmp", "rb"))
tape_tilegrid = displayio.TileGrid(tape_bitmap, pixel_shader=tape_bitmap.pixel_shader)
main_display_group.append(tape_tilegrid)
# song name label
song_name_text_group = displayio.Group(scale=3, x=90, y=44) # text label goes in this Group
song_name_text = tracktext(mp3_filename, 2)
song_name_label = label.Label(terminalio.FONT, text=song_name_text, color=orange_bright)
song_name_text_group.append(song_name_label) # add the label to the group
main_display_group.append(song_name_text_group) # add to the parent group
# artist name label
artist_name_text_group = displayio.Group(scale=2, x=92, y=186)
artist_name_text = tracktext(mp3_filename, 1)
artist_name_label = label.Label(terminalio.FONT, text=artist_name_text, color=orange_bright)
artist_name_text_group.append(artist_name_label)
main_display_group.append(artist_name_text_group)
# song progress bar
progress_bar = HorizontalProgressBar(
(72, 144),
(174, 12),
bar_color=blue_bright,
outline_color=blue_mid,
fill_color=blue_dark,
main_display_group.append(progress_bar)
# volume level bar
volume_bar = VerticalProgressBar(
(304, 40),
(8, 170),
bar_color=orange_bright,
outline_color=orange_mid,
fill_color=orange_dark,
main_display_group.append(volume_bar)
volume_bar.value = mixer.voice[0].level * 100
def change_track(tracknum):
# pylint: disable=global-statement
global mp3_filename
mp3_filename = mp3s[tracknum]
song_name_fc = tracktext(mp3_filename, 2)
artist_name_fc = tracktext(mp3_filename, 1)
mp3_file_fc = open(mp3_filename, "rb")
mp3stream_fc = audiomp3.MP3Decoder(mp3_file_fc)
mp3_bytes_fc = os.stat(mp3_filename)[6] # size in bytes is position 6
return (mp3_file_fc, mp3stream_fc, song_name_fc, artist_name_fc, mp3_bytes_fc)
print("Walkmp3rson")
play_state = False # so we know if we're auto advancing when mixer finishes a song
last_debug_time = 0 # for timing track position
reels_anim_frame = 0
last_percent_done = 0.01
audio.play(mixer)
while True:
encoder_pos = -encoder.position
if encoder_pos != last_encoder_pos:
encoder_delta = encoder_pos - last_encoder_pos
volume_adjust = min(max((mixer.voice[0].level + (encoder_delta*0.005)), 0.0), 1.0)
mixer.voice[0].level = volume_adjust
last_encoder_pos = encoder_pos
if play_state is True: # if not stopped, auto play next song
if time.monotonic() - last_debug_time > 0.2: # so we can check track progress
last_debug_time = time.monotonic()
bytes_played = mp3_file.tell()
percent_done = (bytes_played / mp3_bytes)
progress_bar.value = min(max(percent_done * 100, 0), 100)
if not mixer.playing:
print("next song")
audio.pause()
track_number = ((track_number + 1) % len(mp3s))
mp3_file, mp3stream, song_name, artist_name, mp3_bytes = change_track(track_number)
song_name_label.text = song_name
artist_name_label.text = artist_name
mixer.voice[0].play(mp3stream, loop=False)
time.sleep(.1)
audio.resume()
# Use the NeoKeys as transport controls
for k in range(len(keys)):
neokey, key_number, color = keys[k]
if neokey[key_number] and not key_states[key_number]:
key_states[key_number] = True
neokey.pixels[key_number] = color
if key_number == 0: # previous track
audio.pause()
track_number = ((track_number - 1) % len(mp3s) )
play_state = True
time.sleep(.1)
audio.resume()
if key_number == 1: # Play/pause
if play_state:
audio.pause()
play_state = False
else:
audio.resume()
play_state = True
if key_number == 2: # Play track from beginning
audio.pause()
song_name_label.text = tracktext(mp3_filename, 2)
artist_name_label.text = tracktext(mp3_filename, 1)
play_state = True
time.sleep(.1)
audio.resume()
if key_number == 3: # next track
audio.pause()
play_state = True
time.sleep(.1)
audio.resume()
if not neokey[key_number] and key_states[key_number]:
neokey.pixels[key_number] = amber
key_states[key_number] = False
Reason: please use code tags for embedded code
- dastels
It looks to be the indexing into the mp3s list. What gets printed out just before that when it prints out the filenames?
- Scallopman1739
I don't see anything that gets printed out before. It just shows that screen.
- dastels
OK. Just after the line mp3s.sort() have a line print(length(mp3s)) and let me know what it prints. I'm thinking that the mp3s list is empty.
- Scallopman1739
It's giving me 0
- dastels
That's what I thought. It's not putting any filenames in the list. Do you have mp3 files on the sd card?
- Scallopman1739
I do. There 4 files on there right now
- dastels
Can you add a print in the loop that fills that list. I.e. print each one as it's appended to the list.
- Scallopman1739
Could you give me the code to do that? I'm not sure how to do that part.
