N00ds
Stefan_martin
N00ds
Post by Stefan_martin »
Hello- I’m trying to find the data sheet for the n00ds that shows
Lumens
Mah current
I’m trying to connect five 300mm n00ds to a
3.7v 10000 mah li-po battery in a parallel circuit, and determine how many hours of power it would provide, as well as what kind of resistor would he needed.
Thanks in advance!
barshatriplee
Re: N00ds
Post by barshatriplee »
I think you have to select a particular color. Different color of noods is made of different LEDs. For example, if you select red, you can see adafruit led sequin ruby in the related products. You will find the datasheet of this LED too. Similarly, if you select yellow, the super bright yellow 5mm LED will appear.
