I have a Circuit Playground Bluefruit, and I am doing the project No-solder LED Disco Tie:
https://learn.adafruit.com/no-solder-ci ... -disco-tie
The project powers up just fine with USB cable, but plugging in a battery does nothing. I just got a new battery today, charged it and plugged it in.
Is there something I'm missing here? Thanks.
Circuit Playground Bluefruit, does not turn on with battery
- Eswezey
- dastels
Re: Circuit Playground Bluefruit, does not turn on with battery
Please post a clear picture of the connector end of the battery cable. Where did you get the battery?
- Eswezey
I'll have to send a picture later. Amazon.
- Eswezey
The Amazon listing specifies the battery has a JST-PH2.0 connector.
https://www.amazon.com/dp/B07BTV5Q6F?ps ... ct_details
Bluefruit specs don't say what type of battery connector it is, but the suggested battery for the project says it is JST-PH.
https://www.adafruit.com/product/258
- dastels
Again, please post a clear pic of the connector end of the battery cable.
- Eswezey
Measured the battery voltage at 4.11 volts.
Picture straight-on the connector and board: Picture side-by-side: Picture of the board powered by USB:
- dastels
Thanks. That battery has the wrong polarity for Adafruit boards.
- Eswezey
Dang, you're right. That probably means I can't flip the wires because then it won't charge.
- dastels
As it seems the charger matches its polarity, you are correct. Fortunately it doesn't sound like the CPB was damaged in the process.
You could get something like https://www.adafruit.com/product/1131 and reverse the wiring in one end, for use with the charger. Just be sure to label it clearly!
- Eswezey
Thanks very much for your help!
