Raspberry pi 3 a+ model a plus pi Wi-Fi issues
- Yankstixman
Wi-Fi doesn’t work properly. I’ve tried everything, from stronger power supply to different OS installations. The Wi-Fi keeps losing the carrier every minute or two. It seems the hardware is defected
- Attachments
- 31F4A89F-9D95-4150-A798-7084F8DE8348.jpeg (538.69 KiB) Viewed 101 times
- mikeysklar
Re: Raspberry pi 3 a+ model a plus pi Wi-Fi issues
Did you disable power saving?
check:
temporary between boots:
permanent:
check:
sudo iw wlan0 get power_save
sudo iw wlan0 set power_save off
sudo /sbin/iw dev wlan0 set power_save off
