AHT20 show temperature/humidity in the GUI gauges
AAW172
Post by AAW172 »
Currently, I am working on a code to show the temperature and humidity in my Gui which will be imported to the main code. at first, I followed the tutorial on how to use the aht20: https://learn.adafruit.com/adafruit-aht ... cuitpython.
The example code is working well but my own code has a lot of errors.
Many thanks!
import time
import board
import adafruit_ahtx0
class Temperature_Sensor:
    def __init__(self):
        i2c = board.I2C()
        self.sensor = adafruit_ahtx0.AHTx0(i2c)
    def run(self):
        while True:
            print("\nTemperature: %0.1f C" % self.read_temperature())
            print("Humidity: %0.1f %%" % self.read_humidity())
            # Code for temperature gauges...
            temperature_top = self.read_temperature()
            temperature_bottom = self.read_temperature()
            # Code for humidity gauges...
            humidity_top = self.read_humidity()
            humidity_bottom = self.read_humidity()
            time.sleep(2)
    def read_temperature(self):
        return self.sensor.temperature
    def read_humidity(self):
        return self.sensor.relative_humidity
# Creates an instance of the Temperature_Sensor class
sensor = Temperature_Sensor()
# Starts reading temperature and humidity
sensor.run()
[errors from this code]
  File "/usr/local/lib/python3.9/dist-packages/adafruit_bus_device/i2c_device.py", line 175, in __probe_for_device
    self.i2c.writeto(self.device_address, b"")
  File "/usr/local/lib/python3.9/dist-packages/busio.py", line 196, in writeto
    return self._i2c.writeto(address, buffer, stop=stop)
  File "/usr/local/lib/python3.9/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 52, in writeto
    self._i2c_bus.write_bytes(address, buffer[start:end])
  File "/usr/local/lib/python3.9/dist-packages/Adafruit_PureIO/smbus.py", line 320, in write_bytes
    self._device.write(buf)
TimeoutError: [Errno 110] Connection timed out
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.9/dist-packages/adafruit_bus_device/i2c_device.py", line 181, in __probe_for_device
    self.i2c.readfrom_into(self.device_address, result)
  File "/usr/local/lib/python3.9/dist-packages/busio.py", line 186, in readfrom_into
    return self._i2c.readfrom_into(address, buffer, stop=stop)
  File "/usr/local/lib/python3.9/dist-packages/adafruit_blinka/microcontroller/generic_linux/i2c.py", line 59, in readfrom_into
    readin = self._i2c_bus.read_bytes(address, end - start)
  File "/usr/local/lib/python3.9/dist-packages/Adafruit_PureIO/smbus.py", line 187, in read_bytes
    return self._device.read(number)
  File "/home/Fiberneering/Desktop/rpi files GUI/temperature_Sense_FIB.py", line 35, in <module>
  File "/home/Fiberneering/Desktop/rpi files GUI/temperature_Sense_FIB.py", line 10, in __init__
  File "/usr/local/lib/python3.9/dist-packages/adafruit_ahtx0.py", line 93, in __init__
    self.i2c_device = I2CDevice(i2c_bus, address)
  File "/usr/local/lib/python3.9/dist-packages/adafruit_bus_device/i2c_device.py", line 62, in __init__
    self.__probe_for_device()
  File "/usr/local/lib/python3.9/dist-packages/adafruit_bus_device/i2c_device.py", line 184, in __probe_for_device
    raise ValueError("No I2C device at address: 0x%x" % self.device_address)
ValueError: No I2C device at address: 0x38
This is how the AHT20 is connected to the raspberry pi. It's connected to the 3,3V Pin.
AAW172
Re: AHT20 show temperature/humidity in the GUI gauges
Post by AAW172 »
small update.
I fixed a lot of problems within the code.
but for some reason i can't get the temp_reading_top defined and show me some digits.
        temp_reading_top = temperature_Sens.read_temperature()
        temp_reading_bottom = temperature_Sens.read_temperature()
        humid_reading_top = temperature_Sens.read_humidity()
        humid_reading_bottom = temperature_Sens.read_humidity()
        #code for temperature gauges
        self.meter1 = Meter(self, radius=350, start=0, end=80, border_width=0, fg="#242424", bg="#242424",
               text_color="white", start_angle=270, end_angle=-270,
               text_font="DS-Digital 12", scale_color="white", needle_color="red", text=" \N{DEGREE SIGN}C")
        self.meter1.set_mark(60, 80) # set red marking from 60 to 80
        self.meter1.grid(row=3, column=0, padx=20, pady=10, rowspan=5)
        self.meter1.set(temp_reading_top)
        self.label3 = customtkinter.CTkLabel(self, text="Temperatures")
        self.label3.grid(row=2, column=0, padx=20)
this code should show me the gauges through a import i made.
[code]
    def __init__(self):
        i2c = board.I2C()
        self.temperature_top = 0
        self.temperature_bottom = 0
        self.humidity_top = 0
        self.humidity_bottom = 0
    def run(self):
        while True:
            temp_reading_top = self.read_temperature()
            humid_reading_top = self.read_humidity()
            time.sleep(2)
# Create an instance of the Temperature_Sensor class
# Create a thread for temperature readings
thread = threading.Thread(target=sensor.run)
thread.daemon = True
thread.start()
adafruit_support_mike
I don't see any code in the object's run loop that sets the meter.
