I'm trying to create personalized eyes for my project, changing the shape of it, and I wanted to know how to do that. I think I have to generate images for the iris, sclera and lids and then use the tablegen.py to generate the hex file with those images. But I don't know if there is some software or something secific to generate those images and how should I change the tablegen.py file to accept images that are not 128x128, because I'm using a 240x240 screen and the eyes appear really small on the screen. I think this is because the image used was 128x128, and I wanted to use 240x240 images, but I don't really know if that was exactly the problem or if there was any other way to scale the eyes.
How to create new eyes for the teensy in the uncanny eyes project?
- Jvr98
- mikeysklar
Re: How to create new eyes for the teensy in the uncanny eyes project?
The Teensy 3.2 the guide is based on had a memory limit of 256k. The examples sketches + images were 182K so not enough room to double up on resolution.
Following the Pi guide would allow you more customization and higher resolution.
- Jvr98
Ok, and in order to generate new images, should I be able to do it? Taking into account that the size is the same?
And about the size, in case using another microcontroller with more memory, should I be able to use bigger images?
- mikeysklar
On the Pi side the size can be customized using:
You can generate new images on your Teensy 3.2 based uncanny eyes setup. The guide discusses the process. You will just need to be really careful with image sizes so that the code can fit.
If you were to use another microcontroller you can run the Uncanny_Eyes code on a M4 based processor like the Feather M4 which has 512kB flash. More here on the github repo.
python eyes.py --radius 240
