Order #3078284-9094437790
Pulled camera out of the box, plugged it into my RPi Zero 2, enabled legacy camera on Bullseye through raspi-config, rebooted. Opened terminal, raspistill -o image.jpg, and I get the following error message:
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
followed by "mmal: camera component couldn't be enabled.... failed to create camera component.... Please check for firmware update"
https://forums.raspberrypi.com/viewtopic.php?t=232533
I went to the Raspberry Pi forums, and was recommended to check vcgencmd get_camera. I get "supported=1 detected=1, libcamera interfaces=0"
I went to /boot/config.txt, added start_debug=1, rebooted, ran raspistill again, and get messages of "cannot load camera driver".
I increased the graphical memory to 144 and tried again, with the same messages. I changed the memory to 200, same messages.
I pulled the SD card and installed Buster, followed the same aforementioned steps, and I get the same set of messages.
I get my Pi 3, repeat the same set of steps for both Bullseye and Buster.
I ran across this forum post, which is identical in issue; viewtopic.php?f=8&t=137677. No posted resolution.
No other software I have attempted to use to get an image from this camera works. All of my connections are fine, and I have only disconnected the camera while powered off. I have a V1.3 camera that works fine. No other HQ or GS camera to try.
Global Shutter Camera - Fails to Enable ENOSPC
- LokoManiac
- mikeysklar
Re: Global Shutter Camera - Fails to Enable ENOSPC
Thank you for the troubleshooting summary.
Do you know which ribbon connector you are using with the camera? The Pi Zero family uses a different ribbon than the full size Pi’s.
To use with a Pi Zero, you will need an adapter cable, which we stock here!
*Raspberry Pi Zero models require a Raspberry Pi Zero camera cable (sold separately) to connect.
- LokoManiac
I am using the recommended FPC cable for the Pi Zero that was linked on the GS Camera shop page.
- mikeysklar
Thank you for the ribbon clarification. Let’s try a replacement camera.
Please e-mail [email protected] to request a replacement. They will need a link to this forum thread as authorization and your order#.
- LokoManiac
After a great deal of tinkering, I figured out the issue. I don't know exactly why, but I know how to make the camera work.
If I start from a fresh installation, go straight to using libcamera. The camera works and has no issues. Don't do anything in raspi-config to enable the legacy camera. When I do, I get the error messages that I got before. If I disable legacy camera, the error still persists. So just use libcamera and picamera2 with the HQ and Global Shutter cameras.
- mikeysklar
Thank you for this it will help others to avoid using the legacy camera settings and legacy tools like raspistill.
