1.14" TFT not working as expected
- tpollard49
Re: 1.14" TFT not working as expected
okay, makes sense. How do I fix the issue? Not sure if it's a software issue or if I should just return the product as defective.
- MakerMelissa
It's a software issue. If you look at the previous replies, I mentioned that there's already a bug open at https://github.com/adafruit/Raspberry-P ... issues/235.
- eYeToEyeRob
I’m having the same problem one month later. I bought, assembled and installed the Pi-Hole Kit and it’s working perfectly on my network to kill ads.
But then I started to work on getting the included Mini PiTFT - 135x240 Color TFT working and had the same problem documented in this thread.
Here’s a picture of my screen, and it looks like what others have recorded:
( I previously posted this issue to the wrong forum:)
viewtopic.php?p=973591
So i have two questions:
(1) One month later… is there now a fix for this problem?
(2) If not, if I replace this screen with the square version Adafruit Mini PiTFT 1.3" - 240x240 TFT, or the Adafruit PiTFT 2.2" HAT Mini Kit, will either work correctly?
Adafruit Mini PiTFT 1.3" - 240x240 TFT Add-on for Raspberry Pi
https://www.adafruit.com/product/4484
Adafruit PiTFT 2.2" HAT Mini Kit - 320x240 2.2" TFT - No Touch
https://www.adafruit.com/product/2315
Thanks,
Rob
References:
Mini Color PiTFT Ad Blocking Pi-Hole Kit
https://www.adafruit.com/product/4475
Adafruit Mini PiTFT - 135x240 Color TFT Add-on for Raspberry Pi - Product ID: 4393
https://www.adafruit.com/product/4393
Thanks,
Rob
References:
- MakerMelissa
1. I just wrapped up the last of several other big projects I was in the middle of working on yesterday and am working on the Raspberry Pi display issues today, so if you can wait just a little longer, hopefully I can make a fix available soon.
2. Yes, I have heard from others that the square one does work fine for some reason.
Melissa
Melissa
- eYeToEyeRob
Great! Can I be notified when it’s available?I just wrapped up the last of several other big projects I was in the middle of working on yesterday and am working on the Raspberry Pi display issues today, so if you can wait just a little longer, hopefully I can make a fix available soon.
Thanks,
Rob
- MakerMelissa
Sure, you can go to https://github.com/adafruit/Raspberry-P ... issues/235 and on the right side under Notifications, click subscribe.
- MakerMelissa
I updated the driver itself and just merged my pull request, so it should be working now.
- EarlessPierre
Thank you for the fix! I re-ran the updated procedure described here, but I still seem to have the same issue.
Do I need to run st7789_module/reload.sh manually?
Edit: entirely my fault. Looks like `git clone https://github.com/adafruit/Raspberry-P ... cripts.git` failed because the `Raspberry-Pi-Installer-Scripts` directory existed and then `adafruit-pitft.py` blanked my screen so I didn't see it. Deleting the directory and re-running everything worked perfectly.
- MakerMelissa
Awesome. The reload.sh was just a convenient script I added for reloading the driver after I made changes to the source code.
