I recently completed the AQI in the Learn section, https://learn.adafruit.com/aqi-case and was wanting to change the output from Fahrenheit to Celsius. I tried to change the code around to calculate the reverse of the supplied code. Also, the Faherenheit to Celsius symbol on the screen.
Thanks in advance,
Scott
AQI Celsius Output
- Franklin97355
Re: AQI Celsius Output
This is the part that converts the temperature:
And this is the part that uses the function:
Just temp = scd4x.temperature should work.
def c_to_f(temp_data):
temperature_celsius = temp_data
temperature_fahrenheit = temperature_celsius * 9 / 5 + 32
return temperature_fahrenheit
sensor_check:
co2 = scd4x.CO2
temp = c_to_f(scd4x.temperature)
humidity = scd4x.relative_humidity
- Powderjockey
Thanks @Franklin97355. I'll give it ago.
- Powderjockey
I commented out the "def c_to_f(temp_data):" section and then made "temp = scd4x.temperature" the line.
The temperature has changed, but I don't think it is correct. Showing 28 degrees in the house and that is out about 5. Also, the degree Farhenheit symbol is still on the screen. Line 78, temp_text = bitmap_label.Label(small_font, text="%d" % temp, x=130, y=107, color=0xFFFFFF)
pulls the symbol from somewhere.
- Powderjockey
The image that ships with the program has the Farhenheit symbol aready imbedded on it, so the symbol will never change to Celsius.Powderjockey wrote: ↑Mon Jun 05, 2023 3:37 pm I commented out the "def c_to_f(temp_data):" section and then made "temp = scd4x.temperature" the line.
Thoughts for an update?
- Franklin97355
There is a file called airBG.bmp that you can edit. I did but I can't include it in the forum ( it won't let me)I renamed it with an extension .txt you can see if renaming it .bmp will work. Let me know.
- Powderjockey
FRANKLIN97355, that worked. What did you use to edit it?
- Franklin97355
I used GIMP on a Linux system but it will work with Windows and Mac
